Rear Speed Sensor (ABS) connectors
Old May 3, 2020 | 04:20 PM
mcook's Avatar
Default Rear Speed Sensor (ABS) connectors
I have been troubled for months with intermittent ABS problems (No traction control), which normally clears itself at the next start-up. I have, over time, checked all sensors and connections, apart
from the connections of the two rear ones. What I need is the location of where the short cable from the sensor connects to the cable going to the ABS brake modulator. I think I have an intermittent cable break or connector
and I have thoroughly checked the front, as well as having repaired the soldered power connections on the modulator PCB. I am thinking I might have to remove the rear seat, but I thought I would
ask before starting that job.
Thanks.
Old May 3, 2020 | 04:59 PM
crbass's Avatar
You might want to check the OBD II codes (either your own reader or have Autozone, etc, do it) to see if the car thinks the sensors are the issue. If the car think's it's another issue, you can focus there. Also, there's this bit of troubleshooting information
ABS Sheet XK8.pdf
Old May 4, 2020 | 06:01 AM
mcook's Avatar
Thanks for the info, but I have already traveled that road. What I am trying to find out is the physical position of the connectors of the short cables connecting the rear sensors to the cable heading towards the brake modulator. Are they behind the rear seat? Under the chassis? or some other hidden location. I easily located the connectors of the front sensors, located under the hood on top of the wheel arches, but I can't find the rear ones.
Old May 4, 2020 | 08:20 AM
motorcarman's Avatar
What DTC is logged in the module?
bob
Old May 4, 2020 | 08:41 AM
crbass's Avatar
Connectors BT72 (left) and BT73 (right), located to the rear of the respective rear hub assemblies. Both wires eventually running up to 20 way connector BT2, in the boot/trunk above the rear right wheel arch. Not under the rear seat.
Has the ABS given code(s) for one of these? Your initial message seems to indicate a rather nonspecific problem.
hellokitty
Oct 12, 2018 01:37 PM
Augeter
Aug 5, 2017 09:42 PM
twopumpchump
Dec 8, 2016 08:21 AM
vkng7
Dec 2, 2015 09:21 PM
Bigjeff911
XJ40 ( XJ81 )
May 26, 2011 10:56 AM
