View Poll Results: ok
ok
0%
ok
100.00%
Voters: 1. You may not vote on this poll
rear wheel bearing
Old Oct 29, 2018 | 12:56 PM
Erling Bilstad's Avatar
Unhappy rear wheel bearing
hello.
I replaced the rear wheel bearing because I could feel the tire was loose, but the problem is still there. could it be the shim that is in center of both bearing that is causing the loose space ?
Old Oct 29, 2018 | 01:52 PM
Welcome to the forum Erling Bilstad,
I've closed your POLL. It's not the best way to ask for advice.
Old Oct 29, 2018 | 08:38 PM
baxtor's Avatar
Originally Posted by Erling Bilstad
hello.
Another possibility is diff output shaft bearings. Are you sure the movement is between the hub carrier and hub/wheel and not at the inner end of drive shaft?
Old Oct 30, 2018 | 12:24 PM
RaceDiagnostics's Avatar
Do you have any 3 - 9 movement, there should be none.
12 - 6 movement is normal on these cars.
kain3488
Dec 14, 2018 01:58 PM
psiharath1
Sep 27, 2013 02:53 PM
bojangles
Mar 2, 2008 08:57 PM
rdcsat
Nov 16, 2007 06:20 PM
