View Poll Results: ok
ok
0%
ok
100.00%
Voters: 1. You may not vote on this poll
rear wheel bearing
hello.
I replaced the rear wheel bearing because I could feel the tire was loose, but the problem is still there. could it be the shim that is in center of both bearing that is causing the loose space ?
Welcome to the forum Erling Bilstad,
I've closed your POLL. It's not the best way to ask for advice.
Another possibility is diff output shaft bearings. Are you sure the movement is between the hub carrier and hub/wheel and not at the inner end of drive shaft?
kain3488
Dec 14, 2018 01:58 PM
Xtyper
Mar 28, 2015 02:12 PM
psiharath1
Sep 27, 2013 02:53 PM
bojangles
Mar 2, 2008 08:57 PM
rdcsat
Nov 16, 2007 06:20 PM
