rear wheel bearings
Old Oct 22, 2020 | 11:01 PM
MaxTorq's Avatar
Default rear wheel bearings
hello gents..& ladies,
while the tires were getting rotated i happen to grab and "wiggle" each of the wheels while off the ground. the right rear has a notable amount of movement/ slack. with a little interweb surfing it seems evidently i need to replace both the bearings..? can anyone tell me the timken set numbers needed for the inner and outer ? i don't think i would trust any other source as anywhere near accurate as all the seasoned veterans here..... i thank you all kindly for your shared wisdom in advance.
max &
XKRFACE
Old Oct 22, 2020 | 11:05 PM
MaxTorq's Avatar
i guess i should add...
2005 XKR with 77000 miles...and...
the latest, greatest love of my time...
truly a blessing with every drive !
thx,
max
Old Oct 23, 2020 | 12:28 AM
Johnken's Avatar
Max, 1A Auto parts has Timken inner bearings for $50(ish) a pair (left right).
I just bought them thinking they were a set of inner and outer bearing (ouch).
Good luck finding Timken outer bearings i struck out.. Wound up going to jaguar, $45 for one.
Now, you need 3 other things to do the job. Inner and outer seals, new axle nut (bad idea to reuse). Seals about $12 each. Nut typically $33.
FWIW Jagbits sells a kit (all above + grease) for around $70, but I can't say longevity is that brand's strong point.
John
Old Oct 23, 2020 | 02:37 AM
Try forum Sponsor S N G Barratt for the option of Jaguar OE or aftermarket equivalents:
Rear Outer Hub Bearing
https://www.sngbarratt.com/English/#...0%60CAC6333%60
Rear Inner Hub Bearing
https://www.sngbarratt.com/English/#...21053%20%20%60
Rear Wheel bearing Hub - Kit
https://www.sngbarratt.com/English/#...0%60JLM1708%60
Here's the relevant section from JEPC showing the P/N's:
Old Oct 23, 2020 | 07:48 AM
Johnken's Avatar
Wow, SNG Barrett with decent prices! I'd given up on them long ago. Everytime they've been mentioned as a sponsor just kept quiet thinking emperor with no clothes. I now stand corrected.
Thanks for the links Graham, nice surprise.!
John
elvinjones
Dec 2, 2015 06:31 PM
Sparkers69
Aug 15, 2013 02:35 PM
matjohns
Oct 25, 2010 04:27 AM
Bward
XJ40 ( XJ81 )
Jul 5, 2009 07:23 AM
