Rear windows control switch - correct PIN # ?
Old May 22, 2018 | 04:06 AM
Salo's Avatar
Question Rear windows control switch - correct PIN # ?
Hi All,
can anyone who has installed the switch to be able to control the rear windows
on a XKR convertible manually confirm what PIN numbers You patches into?
are PIN #11 and PIN #15 on the Yellow connector the correct ones to splice into?
reason for asking is that on my XKR 2001 the green/black wire is on PIN #16 !
should I trust the color or the PIN position??
see picture's below for details on my question - many thanks in advance.
green/black wire is on PIN #16 not on PIN #15?<br/>- XKR 2001
switches - one for the antenna, one for the rear windows..
Youtube instructions by Sam..<br/>The wires you are looking for are green/black and green/purple. They are on pins 11 and 15 (on the 2003 they are on pins 16 and 17). So, it's the same connector, but you're looking for the green/black wire on pin 11 and the green/purple wire on pin 15.
Old May 23, 2018 | 03:08 AM
Salo's Avatar
Nobody know this ?, ok
the green/black wire should be on PIN #11, anyway...
- I move it from PIN #16 to PIN #15 the green/purple today and give it a test...or maybe I'm getting color blind
Old May 23, 2018 | 04:00 AM
Salo's Avatar
PIN #11 and PIN #15 are WRONG - atleast on my car - get suspension error warning on the display and nothing happens to the rear windows...so I give this up !
Old May 23, 2018 | 04:34 AM
Salo's Avatar
ok I guess I just f-ck up the ACDM control unit..
Old Jun 18, 2018 | 10:31 AM
Salo's Avatar
Thumbs up RESOLVED !!! Suspension fault - "CATS" SUSPENSION MODULE LJA1970AB - Jaguar XKR
YES - finally resolved the problem with my "Suspension fault" error code on the console - Lucky me I am so happy now that I finally fixed this issue - the solution was a replacement CATS Suspension module with all # matching as original in my car - removed the grund from the battery - connected the replacement module - error code gone !!! - - reason for the fault was in my case that I tried to connect a manual switch for the rear small windows - however the recommend PIN # to patch into turned out to be totally wrong.
phuuu - lessons learned from this story is that NEVER EVER PATCH INTO WIRES YOU ARE NOT 100% SURE ARE RIGHT
fix(resoution)- replacement module with matching numbers - "CATS" SUSPENSION MODULE LJA1970AB - Jaguar XKR ... -from eBay
no more "suspension fault" error code )
2015Coupe
Nov 8, 2017 01:05 PM
09XFwhippin
Nov 28, 2016 11:22 PM
64vette
Jan 9, 2016 06:13 PM
davesnewgrl
Jul 24, 2014 01:22 AM
Lear45
May 20, 2014 08:02 PM
