Rear wings/boot - Paint or Wax? Advice please
Old May 4, 2015 | 03:32 AM
scoobie's Avatar
Default Rear wings/boot - Paint or Wax? Advice please
Lower rear wing sections accessible from inside the boot.
I have been de-rusting these for a couple of weeks now but were quite bad and still aren't perfect but haven't yet caused bubbling on the exterior of the wing.
Question I have is whether to paint with a good anti-rust paint with the risk of moisture creeping under the paint causing more rust in the future OR whether to use a 'corrosion prevention' wax e.g. Dinitrol ML which I have already injected into the chassis rails and sills?
I am leaning towards the wax but realise that if it doesn't work then it will be a b*tch to remove if I want to paint later.
Any ideas please?
Regards
Mark
Old May 4, 2015 | 05:17 AM
plums's Avatar
You first need to treat the area with a rust converter, which is generally
phosporic acid. Unless of course that is what you mean by de-rusting.
Old May 4, 2015 | 05:33 AM
scoobie's Avatar
Plums,
Yes I have used some quite expensive rust removal solution that is used in the aviation industry, however the area is quite pitted so I am never going to get down to 100% shiny steel.
I am just doing final prep (whilst we have some sunshine today) and am considering painting it then when dry flooding the area with Dinitrol.
I think that most UK XK8s will have this problem as it seems to be a rust-trap area.
Mark
Old May 4, 2015 | 05:50 AM
plums's Avatar
In a similar situation, I did the rust conversion, then covered the whole thing
in fiberglass + epoxy. The thought was that once oxygen could not get to
the remaining rust, the rust could not progress.
Old May 4, 2015 | 05:59 AM
scoobie's Avatar
The rustbusters paint I am using is 2-part epoxy so hopefully I will get similar results.
The reason for my question was that in a similar situation where access is limited e.g. chassis rails the normal procedure would be to use wax with the expectation that it would halt further corrosion.
Old May 4, 2015 | 09:46 AM
scoobie's Avatar
This should be the last bit of painting before the (rebuilt) rear axle assy gets reunited.
Can't wait to get it back on its rear wheels again .
- Scoob
Old May 4, 2015 | 02:36 PM
RJ237's Avatar
I would be satisfied with the two part epoxy paint as a sealer.
JagBrian
Aug 18, 2019 05:07 PM
Dz1rfj
Jul 17, 2018 10:29 AM
WinterJag
16
Oct 9, 2015 07:49 PM
Dz1rfj
Sep 16, 2015 03:44 PM
davidladewig
Sep 3, 2015 06:32 PM
