Recomend gasket sealer for water pump
Old Sep 25, 2011 | 04:51 PM
djpxk8's Avatar
Default Recomend gasket sealer for water pump
I am just about to fit a new water pump, can anyone recomend a good gasket sealer, and where to purchase it?
Many thanks,
David
Old Sep 25, 2011 | 05:42 PM
bt965's Avatar
Shoudn,t need one if both surfaces are well cleaned
Bob
Old Sep 25, 2011 | 08:16 PM
mike66's Avatar
None needed.
Old Sep 26, 2011 | 11:56 AM
DrDSP's Avatar
Many thanks,
David
A few months ago I replaced the waterpump in my 2003 XKR with one with a metal impeller . The instuctions said to use a gasket sealer. I used VersaChem type 2 Gasket Sealer (I think I purchased it from Kragen). No leaks or issues at this point.
Old Sep 26, 2011 | 07:46 PM
mike66's Avatar
oh-oh, time for the experts to set us straight. I just bolted mine on w/o and had no problem. I suppose if the gasket stuff is compatible with the gasket material, then what harm can it do?
Old Sep 26, 2011 | 10:45 PM
Brutal's Avatar
depending on the style, you use either a steel shim embossed gasket, or a aluminum oringed gasket. neither use sealer
Old Sep 27, 2011 | 01:32 AM
XKRacer's Avatar
I don't use sealant, as Brutal says, comes with a crush type gasket, but I have noticed a lot of 'refurbed' water pumps hitting the market place with paper gaskets?
silkcat
Jan 18, 2025 04:29 AM
Wahooesprit
Dec 23, 2019 02:01 PM
picard
Oct 12, 2015 11:56 AM
Jaiello21
Sep 14, 2015 09:42 PM
chatmanx
Sep 11, 2015 07:17 PM
