Red LED Light Replacement on Shifter J Gate
Old Oct 28, 2025 | 03:59 PM
Chris Lutz's Avatar
Default Red LED Light Replacement on Shifter J Gate
Hello. Is there any way to repair or replace the small square red LED lights on the J gate shifter that note each shifter position? I was able to unsolder and resolder new light bulbs in, and those work fine, but I have two burned out red LED lights at the "D" and "4" positions on the J gate. Can these be repaired/replaced, or is the only solution to find another circuit board where all the red lights work? I didn't want to start digging around before I asked the group. Thanks as usual.
Old Oct 29, 2025 | 01:09 AM
Y2KJag's Avatar
I sent mine off to Module Masters, IIRC. They replaced all the lights on the shifter mechanism with LED. I don't trust myself with a soldering iron.
Old Oct 29, 2025 | 05:32 AM
michaelh's Avatar
They're surface mount components, so it will test your eyesight & soldering skills...
Worth checking with a meter that they're really dead?
Mouser has a good few options, e.g. something like this:
https://www.mouser.com/ProductDetail...PHkSlKww%3D%3D
Old Oct 29, 2025 | 10:16 AM
Chris Lutz's Avatar
Thanks, that looks like the LED, or at least very very close. I'll have to get the magnifying glass out and see exactly how those things are attached and if I can even get to them.
Old Oct 30, 2025 | 04:34 AM
dibbit's Avatar
If you've not attempted this kind of repair before, it's worth practicing on some scrap electronics first, or just take the board to a repair place. Pretty much any electronics repairer can do it, even a mobile phone repair place might have the tools.
First though do what Michaelh suggested and check they are actually dead and that this isn't some other fault.
You could also very carefully measure the voltage across the working LEDs to see what spec your new ones need.
Old Oct 30, 2025 | 05:09 AM
Chris Lutz's Avatar
Thanks, this is good advice. I had a scrap circuit board that I ruined previously, and I was able to un-solder two known working LEDs from that and solder them onto the non-working locations on my "new" circuit board. They still don't work, so I probably didn't do it correctly, or, as you said, there is another fault in the circuitry itself. I'll look into an electronics shop, that's a great idea, although not sure how they can test it without it being attached to the car wiring.
Old Oct 30, 2025 | 05:24 AM
dibbit's Avatar
You can test the LEDs on the board with it out of the car, with a multimeter. Set the meter to Ohms range and measure across the LED, note the reading and take the measurement again with the leads swapped. One direction should give a high resistance and the other a low resistance. If you get the same each direction, then the LED is probably dead. Find a youtube video for better instructions.
You also need to bear this in mind if replacing the LEDs - they only work one way around.
Old Oct 30, 2025 | 05:37 AM
Chris Lutz's Avatar
Thanks, I'll try that out.
CorStevens
Jul 14, 2019 09:54 PM
KVO
Sep 18, 2018 11:58 AM
Heliwilly
May 6, 2015 04:50 AM
Spikepaga
Nov 30, 2014 03:52 PM
04xtype04
Apr 29, 2014 09:20 PM
