Sensor location?
Old Oct 28, 2025 | 12:54 PM
Emerald XK8's Avatar
Default Sensor location?
Hello all!
Emerald is showing a code P0706-transmission range sensor "A" fault. Can anyone tell me is that the same as the NSS on the side of the transmission? Or is it somewhere else?
Old Oct 28, 2025 | 12:55 PM
Originally Posted by Emerald XK8
Hello all!
shes a 2000 XK8 Coupe 4.0
Old Oct 28, 2025 | 02:07 PM
motorcarman's Avatar
The D4 switch is the most common fault for the P0706 DTC.
If the switch is displaced or broken you will get the DTC.
If the plastic cam plate is loose or broken you will get DTC.
Selecting 4, 3, 2 on the J gate will trigger the fault if the D4 switch does not operate correctly.
File Type: pdf
Old Oct 28, 2025 | 02:24 PM
Sounds like exactly what i'm after! P-d shes happy. Throw her left she throws a fault. So where is the D4?
in the shifter?
Old Oct 29, 2025 | 05:04 PM
Is this the D-4 switch? If so i understand why mine is throwing a fit!
Old Oct 30, 2025 | 09:06 AM
Where is the plastic cam plate?????
Old Oct 30, 2025 | 12:41 PM
I'm not sure what happened to the one in the video, he never says. HOWEVER i found mine in the floor in pieces. I need one. BOB SIR, may i tell you what my car is doing and see what you think?
Old Oct 30, 2025 | 01:18 PM
The cam plate is part of the selector lever illumination module.
The plastic plate that operates the D-4 switch and follows the selector lever is NSS.(Not Sold or Serviced Separately)
You have 2 choices.
Do NOT use the left side of the 'J' Gate.(no 4,3,2)
or
Find and install a used 'unbroken' plate from another illumination module.
NOTE: There are several different selector lever illumination modules for different gearboxes but the plastic plate should fit most cars with 5 speed gearboxes.
Old Oct 30, 2025 | 02:34 PM
Ok thank you sir!
ocwolfy
Apr 5, 2024 04:02 AM
Gearhead01
Feb 16, 2023 02:27 PM
zaid
XF (X260)
Aug 7, 2022 09:32 AM
cruisesinc
May 30, 2012 01:36 PM
carlorner
Aug 29, 2011 12:17 PM
