Refitting Console With Key In Ignition Now Wont Start Limiter Not Available ?
Old Jun 9, 2012 | 02:16 PM
jagxkrtoofast's Avatar
Banned
Arrow Refitting Console With Key In Ignition Now Wont Start Limiter Not Available ?
So I was refitting center console dash. I kept the key in the ignition then I try to open the driver door and it wouldnt let me. So I had to get out on passenger side. Alarm went off I pressed the key. Now When I put my key back in ignition to start I get these messages "Limiter Not Available" and "Cruise Not Available" it wont let me turn the key to start the car. Please help. Thanks
Old Jun 9, 2012 | 02:54 PM
Banned
Windows wont roll down nor radio wont turn on either. Should I do a hard reset ?
Old Jun 9, 2012 | 03:15 PM
Red1bw's Avatar
When you put the console in did you replug the harnesses....not just cigarette lighter, but the sport switch and adaptive cruise (if fitted)?
Old Jun 9, 2012 | 03:30 PM
Banned
I tried all of that I did a hard reset and now the doors wont even lock unless I use the key in door. It wont let me turn the key ignition. I get a message now DSC Fault, Limiter Not Available, and Cruise Not Available.
Old Jun 9, 2012 | 03:46 PM
Banned
Now it says Gearbox Fault, RP, Suspension Fault, Electrical Fault after I disconnected battery. Still wont let me turn the key over. It appears Im not getting any power at all. Windows wont roll radio doesnt turn on either.
Old Jun 9, 2012 | 04:08 PM
Banned
Help
Old Jun 9, 2012 | 05:28 PM
Red1bw's Avatar
I would back-track whatever you did. Car worked fine I assume.....you did something with the console off.....put it all back....and now car doesn't work. I would think it is most likely that whatever you did either directly or indirectly resulted in your current situation.
Did you spill anything on wiring? Specifically what did you install / fix / do to the car since it last worked well? Did you disconnect those console harnesses and other harnesses while key was in ignition, battery was connected, and they were powered? If so, I would check fuses first....and there are potentially a lot.
Old Jun 9, 2012 | 07:36 PM
Banned
Ok so I disconnected the battery for like hours and reconnected back. Now the power is restored. However I only just get DSC Fault message thats it. I believe my battery is drained so I will have to charge it. Now I have to reset everything bc the windows are not in sync.
Old Jun 11, 2012 | 11:35 AM
Banned
I tried to jump the battery now all the power is off again and the codes are Limiter Not Available, Cruise Control Not Available. Please help.
Old Jun 11, 2012 | 11:39 AM
WhiteXKR's Avatar
Charge your battery...do not rely on a jump. If you still have problems get your battery checked at Autozone or Advanced Auto.
Any other troubleshooting is a waste of time unless you are sure your battery is good.
Old Jun 11, 2012 | 12:29 PM
Banned
Ok I charged the battery up and it started. There is no codes.
Old Jun 11, 2012 | 05:40 PM
Banned
Update: Everything is fine no more messages.
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Jaguar Forums Editor
Jaguar Press release
Sep 3, 2015 09:38 AM
XFR_Gold
Sep 2, 2015 12:24 PM
