Removal of Radiator Without Loss of ATF
Old Jan 22, 2018 | 04:46 PM
JBD714's Avatar
Default Removal of Radiator Without Loss of ATF
Is there any way to remove the radiator without losing automatic transmission fluid ? I dread having to go under the car to add ATF. Can I plug the openings on both sides and then add fluid as I reattach the radiator via one of the lines back to the transmission?
many thanks in advance!
Old Jan 22, 2018 | 04:51 PM
fmertz's Avatar
Remove the top line first. A little fluid comes out. If you can, capture it (or at least figure out about how much comes out), and add it back later. Once the top line is open, the fluid drains back into the trans through the bottom line. Then disconnect the bottom line. Should have a few drips at the most from the bottom line...
Old Jan 22, 2018 | 04:58 PM
JBD714's Avatar
Thanks for super quick reply!
Old Jan 23, 2018 | 06:59 PM
Brutal's Avatar
its not enough to affect the operation of the trans as long as at the correct level before hand
Old Jan 26, 2018 | 04:44 PM
OhWhatNow's Avatar
I pulled the trans cooler out of a leaking radiator on my 02 and measured the capacity. It held only 4oz.
Pristine97XK8Convertible
Sep 16, 2016 11:59 AM
and1carter
Mar 7, 2014 08:02 AM
scarbro2011
Jan 16, 2014 12:15 PM
Louenigma
Jun 11, 2013 04:33 PM
iownme
Dec 9, 2012 06:49 PM
