close
- Join DateDec 2011
- LocationDurham, UK
Liked:17,003 Times in 12,221 Posts
Quote:
1999/XK8/4.0
No power as in 'completely dead' or partially functioning but won't track backwards / forwards to allow access to the four securing bolts?Originally Posted by Fn2damax
HELP! How do I remove my front drivers seat, if it hos no power?1999/XK8/4.0
H20boy
close
- Join DateMar 2007
- LocationOak Ridge, TN
Liked:1,163 Times in 761 Posts
i read someone said you could put power to your seat track motor from an outside battery and then get the bolts out that way. I suppose power to the module would do the same thing...depends if you can reach it.
Get your electrical schematic and see if you can 'jump' the seat!
close
- Join DateDec 2011
Quote:
1999/XK8/4.0
Very little space to work under there especially if the seat is stuck in the fully lowered position. Originally Posted by Fn2damax
Dead! 1999/XK8/4.0
H2Oboy has the best plan but if that doesn't work, you'll have to look at moving it manually. The track motor for front to rear movement is item 3 on the top drawing:
XK Front Seat.pdf
See if there's a square on the drive or on the motor you can get a wrench on to turn.
WhiteXKR
close
- Join DateApr 2010
- LocationArlington VA USA
Liked:3,019 Times in 2,141 Posts
Assuming the passenger seat is working, try swapping controllers (the grey box under the seat) between passenger and drivers seats temporarily.
close
- Join DateDec 2011
Quote:
+1Originally Posted by WhiteXKR
The case lid is weak and often found damaged. The securing bolts on mine were completely ripped out and I had to replace it:
Shown here with the seat out but you can easily get to them with the seat in place.
Let's see if this link will work. I was able to jumper my seat motor to move it back and forth, when I was unable to do so using the switches and such. See the bottom of this thread -
Steve
https://www.jaguarforums.com/forum/x...xtracts-55313/
Steve
close
- Join DateDec 2011
Which diagram? I posted one and Steve8 linked to several.
