Replace Valve cover gasket on 2001 XK8
Old Mar 11, 2014 | 05:06 PM
djpxk8's Avatar
Default Replace Valve cover gasket on 2001 XK8
I want to replace the valve cover gasket on my 2001 XK8, I know I have seen the instructions with pictures on this forum. However, I cannot find them after multiple searches so can anyone PLEASE send me the links I need for this job???
I really appreciate your help, David
Old Mar 11, 2014 | 06:24 PM
bsprowls's Avatar
See if these help you out:
File Type: pdf
File Type: pdf
Old Mar 11, 2014 | 08:18 PM
aode06's Avatar
Its not a bad job, however, I would also suggest a few things:
1.Use brake cleaner 5 cans, to clean the inside and outside of valve covers and cylinder head surface.
2.Apply a thin layer of rtv around the entire head, as the valve covers are warped bad and flex a lot.
3. Replace the breather filter element in the valve cover, as well as replacing the sparks plugs after the proper gap is set.
4.Unclog the breather port tube on the driver side head with a safety pin or paper clip.
5.Be gentle, the connectors love to just break apart when you undo the tabs,trust me, I know.If the connector lock tab does break,simply put a little dab of rtv on the surface it connects to and slide on, then let dry, works every time.
6.Change your air filter and oil if needed, contamination in old oil breaks down gaskets.
Old Mar 12, 2014 | 06:44 AM
JSC's Avatar
JSC
Just 1 item to add to aode06.
7. Do not over-torque!
Old Mar 12, 2014 | 09:28 AM
Spinedoc2304's Avatar
OK, dumb question. What's rtv?
Old Mar 12, 2014 | 09:38 AM
Paul Pavlik's Avatar
Room Temperature Vulcanizing sealant.
Not really necessary unless the Cam Covers have Warped.
Old Mar 12, 2014 | 10:15 AM
Thanks, Paul
Old Mar 13, 2014 | 11:51 AM
djpxk8's Avatar
Smile
I have now finished the job, thank goodness, so far no smell of burning oil.
However, I did break the plastic pipe which connects to the purge valve?on top of the valve cover, trying to get the pipe out of the head!!!
What is the correct method of removing that pipe?? I think its called the "purge Valve" Do you just pull it out by force??
Many thanks for all your help and information for this project.
Old Mar 14, 2014 | 08:26 AM
aode06's Avatar
do not overtorque
Lol you are correct, I have the feeling in my wrist now lol after doing the job twice.The black rtv did wonders.And the surface of the heads are so shiny and smooth, that future removal of the rtv is cake work,comes right off.
Now which side pipe did you break?Got pics?, so we can work up a solution to repair.The BREATHER pipe lol, I have a 1998, so I guess thats what yours is, thats what mine was, and it came out with a little force applied by a pry bar carefully(driver cam cover side).
Old Mar 14, 2014 | 09:21 PM
djpxk8's Avatar
The plastic pipe I broke was on the breather vent into the Valve cover on the drivers side (see picture)
I cut a piece of plastic piping about 2 inches long and then slit it down the middle. I opened up the piping and inside on the bottom put a thick layer of epoxy resin. I then put the opened piping under the split plastic pipe to support the slit. Then I poured epoxy resin over the top to completely cover the split in the black plastic pipe.
So far everything seems to be working OK, no error numbers being thrown!
I have tried to upload a picture of the file but not sure it will show as an attachment??
Old Mar 15, 2014 | 09:22 AM
That is the Part Load Breather. To release it, you slide out the Plastic "C" Clip (facing the driver's seat in your picture) and then Squeeze the little plastic "Bridges" on the connector. This forces the retaining ridges (pointing crosswise on your picture) to release the connector. Then you wiggle it a little as you pull it off.
Old Mar 15, 2014 | 09:35 AM
aode06's Avatar
ok, I hpoe that holds,usually oil vapor is warm, and then oily at the same time.
This breaks down a lot of stuff over time.
But its not a mechanical issue, that can always be repaired later with the original parts or other method, shall the resin fail you at a later time.
Old Apr 19, 2015 | 09:43 PM
radar's Avatar
Default Simple tool to aid in removal of valve cover bolts
The bottom rear bolt of each valve cover is hard to remove because of the limited clearance between the bolt on the heat shielding.
I made a simple adapter tool to fit in the space where universal socket joints would not fit.
Purchase a 3/8" drill adapter with a BB detent bump- @ $2
You could use 3/8" square stock - but it won't stay in the 10mm socket
Grind down and file to fit 11mm wrench
Cut off shank - to a length of @ 7/8"
Stuff a towel under the last bolt in case the part slips off the bolt head
Once the bolt is broken free, you can use an open end wrench to turn
Could not however use a torque wrench to tighten to specs.
Attached Thumbnails Replace Valve cover gasket on 2001 XK8-drill-adapter.jpg   Replace Valve cover gasket on 2001 XK8-drill-adapter-cut-ground-down.jpg   Replace Valve cover gasket on 2001 XK8-11mm-wrench-adapter.jpg   Replace Valve cover gasket on 2001 XK8-installed-valve-cover-bolt.jpg
xjrjag
Nov 27, 2025 09:16 AM
tony bosco
Sep 1, 2015 02:06 PM
Bcrary3
Aug 31, 2015 11:29 AM
SD96XJ6L
Aug 29, 2015 03:20 PM
peterg19
Aug 28, 2015 08:42 AM
