Replaced battery, now radio is dead
Old May 10, 2018 | 04:22 PM
TreelandXK8's Avatar
Default Replaced battery, now radio is dead
I had a dead battery now the radio is dead. I replaced the battery and started right up. Before I go looking for a fuse, is there some reset trip that needs to be done?
2001 XK8
Thanks,
Old May 10, 2018 | 05:32 PM
DevonDavid's Avatar
Not being patronising, but you DID push the on/off button didn't you ?
Old May 11, 2018 | 02:21 AM
Originally Posted by TreelandXK8
I had a dead battery now the radio is dead. .....
Welcome to the forum TreelandXK8,
The three things that need to be done following a battery disconnect/reconnect are:
1. reset clock
2, reset radio presets
3. reset window travel limits
European vehicles (and a tiny number of US vehicles) are fitted with coded radios but this does not prevent them from powering ON.
The radio will power ON after a reconnect provided it is not switched OFF and there is power to the head unit.
Old May 11, 2018 | 08:52 AM
Of course. I haven't gotten into the fuses yet, though.
Old May 11, 2018 | 11:25 AM
Lady Penelope's Avatar
Real quickly there are 3 power fuses on the stereo system
Old May 30, 2018 | 11:04 AM
Thanks, all. I tried all of the fuses.
It looks like I will be pulling the radio out to see if there is power. I am afraid that the radio might have been damaged in a jump start attempt.
Old May 30, 2018 | 03:53 PM
WhiteXKR's Avatar
It would not be the first. Usually you can get an used replacement on eBay for a reasonable cost.
Old Jun 1, 2018 | 06:17 PM
jetworks's Avatar
Try leaving the car locked for a few days. Then start and hold the am/fm button along with the mode switch. My radio popped up the code msg and all is working again. Worked for me good luck����
jhines
Sep 13, 2013 06:15 AM
apexjag
Dec 22, 2011 09:16 PM
supraman
Jul 17, 2011 11:14 PM
Strafe
Aug 16, 2010 09:47 AM
boonchie
Apr 27, 2008 08:11 AM
