Replaced Front Brakes - NOW ABS Traction Light is on. Please help!!!
Old May 28, 2013 | 09:54 AM
pynzenyk's Avatar
Default Replaced Front Brakes - NOW ABS Traction Light is on. Please help!!!
Hi,
I just purhased a 2000 XK8 Convertible with 74K miles. The previous owner replaced 2 front brakes 2 weeks ago and now the ABS light is on and the traction control message is on.
How do I handle this? Do I need to replace/clean front sensors or need to change the ABS control module?
Thanks!
Old May 28, 2013 | 10:03 AM
Jon89's Avatar
First things first. Clean the sensors and check the condition of their wiring harnesses. Dirty sensors and damaged wiring harnesses create the majority of these issues that we all have to deal with. Plenty of threads here in the XK8 section that inform you how to go about cleaning the sensors and repairing faulty wiring harnesses....
Old May 28, 2013 | 10:22 AM
Welcome to the forum pynzenyk,
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old May 28, 2013 | 10:30 AM
RJ237's Avatar
If you still have a problem after following Jon's advice, the following article on jagrepair.com might help. Note that a couple lines below the top there is a link to a checklist:
JagRepair.com - Jaguar Repair Information Resource
Whatever you do, don't buy a used module, it might also be defective. The most common cause of the abs light after dirty sensors and bad connector wires is the solder joint to the abs pump within the module. You can repair it yourself or go to ebay for repair services.
Old May 28, 2013 | 10:34 AM
RJ237's Avatar
I just noticed you are in the Atlanta area. If you are not too far from Douglasville you can bring it to me, I have the Autoenginuity software to read Jaguar codes, and can pinpoint the problem.
Old May 28, 2013 | 12:27 PM
pynzenyk's Avatar
I'm in Alpharetta, about 45 min away. I am new to this forum and can't email you directly.
My cell is 770*990*xxxx. please call me or text me your contact info.
Old May 28, 2013 | 01:38 PM
RJ237's Avatar
It is not good practice to post your phone number on an open forum. Now that I have it maybe one of the moderators will remove your message.
Old May 28, 2013 | 04:59 PM
plums's Avatar
done ... although a user can also edit their own messages
philwarner
Dec 6, 2021 07:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Jimscriv
Nov 4, 2015 02:18 PM
Goncalo Proenca
Sep 8, 2015 06:06 PM
big d
Sep 3, 2015 07:37 PM
