Replacing all coolant/heater hose
Old Mar 11, 2025 | 04:06 PM
pcolapacker's Avatar
This cannot be considered a hijack because I started the thread.
Sometimes brand name means nothing. Wanted to replace injectors on my Carerra. Pelican parts was having a sale from around $120 to $60 each for Bosch fuel injectors. The also had Porsche brand injectors for $360 each. I knew Bosch were OEM so I called and asked what was the difference. Answer: same Bosch injector inside labeled Bosch but little cardboard box say Porsche.
Old Mar 11, 2025 | 04:31 PM
michaelh's Avatar
Sounds like the Jaguar alternator LNC1800AA/DAN672
Denso in a Denso box Ł150
Denso in a Jaguar box Ł1,100
Old Mar 11, 2025 | 05:37 PM
2003RagJag's Avatar
Originally Posted by pcolapacker
RockAuto had everything but spider/octopus hose and T connector. Found those at AutohausAZ. Unless something is a closeout, I've never seen anyone beat RockAuto prices. Besides those two also have used Parts Geek and FCP. They are a little bit more than RockAuto. I see members using JagBits and SNG Barrett. Their prices for the Jag original are insane and even the aftermarket are 2 to 3 times as much.
I found my leak at this one way check valve area. Can it be bypassed?
Old Mar 11, 2025 | 11:37 PM
Y2KJag's Avatar
Replace the check valve. It's there for a reason.
Old Mar 12, 2025 | 05:50 AM
michaelh's Avatar
^^+1
It is available separately (part # MJA6732CA), but you will pay handsomely for it, I'm afraid.
If the octopus is of any age, I'd suggest replacing it complete.
See this thread from Johnken:
https://www.jaguarforums.com/forum/x...5/#post2411800
Old Mar 12, 2025 | 05:57 AM
Rishi's Avatar
I replaced the valley hoses and within a week my radiator sprung a leak. Might be worth replacing that too if it is still the original. It has plastic side pods which is a weak spot.
Old Mar 15, 2025 | 04:11 PM
Photos showing access with manifold tilted and throttle body out.
Old Mar 15, 2025 | 05:11 PM
  #28
JACKP's Avatar
Some recommend replacing the knock sensors while the intake is off.
Jack
Old Mar 15, 2025 | 06:25 PM
Jack
I’ve done it with manifold on, but not bad idea.
Old Mar 15, 2025 | 06:30 PM
  #30
Helpful items. Little spray of silicone on outside of hose for clamps to slide into place. Hoses sliding on fine. To remove had to cut most length wise at connection because 23 years had glued hose to metal and not much room to pull and twist.
Old Mar 15, 2025 | 08:59 PM
  #31
Both original and replacement hose on right have this partial kink. Doesn’t seem right. Can someone send me a pic of theirs?
Old Mar 15, 2025 | 09:24 PM
  #32
Moving these connectors made room for octopus hose. Should have done when removing old one.
Old Mar 15, 2025 | 10:34 PM
  #33
Y2KJag's Avatar
The weird kink is correct. Mine had it too. Don't sweat it.
Old Mar 16, 2025 | 11:36 AM
  #34
Unicorn tears
Old Mar 16, 2025 | 02:40 PM
  #35
Y2KJag's Avatar
When I pulled my intake off and was cleaning it up, I looked at that stupid little plastic sleeve in the elbow. I went to pull it out to clean it and it disintegrated. Very brittle from 20-odd years, I suppose. Very frustrating.
I'd love to know if anybody knows of a suitable replacement. I stuck the hose back into the elbow and surrounded it with some Hondabond. It still has a small vacuum leak, but not serious.
Old Mar 16, 2025 | 03:04 PM
  #36
michaelh's Avatar
You need a C2S15816. It's flagged for the S-type, but is the same.
Strictly, you only need the insert.
The trick to disengaging the vac pipe from the TB is to press the black insert into the ferrule while pulling (gently) on the pipe.
Old Mar 16, 2025 | 03:39 PM
  #37
Wasn’t trying to remove, just bumped when wrestling hose in.
This also broke. Pic is post repair.
Old Mar 16, 2025 | 03:41 PM
  #38
Added a zip die to keep octopus away from cat.
Old Mar 16, 2025 | 03:43 PM
  #39
Y2KJag's Avatar
Híjole!! $40??
But, seriously, thanks!! I guess I'll have to get one.
When disassembling I got the hose out OK. But when futzing with the black plastic part during cleaning it just disintegrated. Yay, plastic!
Old Mar 16, 2025 | 04:19 PM
  #40
michaelh's Avatar
Yeah, one of the legs fell off mine first time around.
I'm afraid Jaguar spares prices have gone silly over the last 3 or 4 years. I paid less than $10 for that kit in 2020
