Replacing Aux drive and SC belts will a basic wrench work?
Old Apr 6, 2020 | 11:49 AM
Grif's Avatar
Default Replacing Aux drive and SC belts will a basic wrench work?
Hi Folks... using the CV down time to get some much need work done to the car.
Managed to replace the coolant expansion yesterday thanks to a couple of informative posts here!
Next up are the 2 belts. I get significant squeal around this time of year (yes, weird. Must be a temp fluctuation thing as it goes by mid spring!) Going to replace the belts first see if that helps. The Aux belt is showing slack on the tension marker. Not a lot but it's just past the lower guideline. So hoping it's that.
One thing I don't have is a specific wrench for the bolt on the tensioner pulley. I do have a bog-standard ratchet socket wrench about a 7 1/2 inches long. Would this suffice do you think or should I buy something more specific for the task?
Grif
Old Apr 6, 2020 | 12:06 PM
rothwell's Avatar
I think it would be more difficult to do it using a tool that short, but probably doable. There is not that much spring tension to deal with.
I used a 3/8 torque wrench that was 18" long. That worked really well. Got it at Harbor Freight for under $20.
Old Apr 6, 2020 | 12:30 PM
RJ237's Avatar
Just find a piece of pipe that will slip over the handle to extend it.
Old Apr 6, 2020 | 12:40 PM
Jon89's Avatar
^^ What he said....
Old Apr 6, 2020 | 01:23 PM
motorcarman's Avatar
The SC belt tensioner will need to be removed or at least loosened to access the FEAD belt (Front Engine Accessory Drive).
The belt will be 'trapped' near the alternator.
Old Apr 6, 2020 | 01:48 PM
Grif's Avatar
ok. First problem. The SC belt tensioner. Can’t get my socket in there. Gap between fan and hope is too thin.
Old Apr 6, 2020 | 02:06 PM
sanchius's Avatar
I found it pretty trivial to remove the fan unit.
Old Apr 6, 2020 | 02:08 PM
Grif's Avatar
OK I'll give that a shot in the AM...light fading now. Thanks for replies folks :-)
Old Apr 6, 2020 | 02:09 PM
Grif's Avatar
Worked perfectly BTW :-)
Old Apr 6, 2020 | 02:56 PM
mcook's Avatar
Exactly what I do as well!
Old Apr 6, 2020 | 03:52 PM
Dr. D's Avatar
Here is a thread that includes more quirks that some but not all may have. It includes some more fabricated wrenches or which one is my double ended wrench that alone will remove both of my belts. (Your results may vary)
https://www.jaguarforums.com/forum/x...engine-169919/
funracer
Aug 10, 2019 10:34 PM
xjfourty
Mar 27, 2018 07:21 AM
Richter12x2
Nov 18, 2015 09:20 AM
Michael Star
Sep 23, 2012 07:07 PM
