Reset door window
Old Mar 13, 2020 | 09:18 AM
DBC's Avatar
DBC
Default Reset door window
2005 XK8 convertible. When I open the door and the window drops a little bit it won't go back up when I shut the door. The left time this happened my shop just had to "reset" the window? How do I do that to see if it will fix it again?
Old Mar 13, 2020 | 09:47 AM
rothwell's Avatar
Run the window and hold the button until the window stops moving and you hear a click about a second later. You need to get the click in both directions.
Old Mar 13, 2020 | 04:06 PM
DavidYau's Avatar
Default Probably low battery charge
Get battery tested. Most garages will do it for free. If it’s old, just get a new battery. If car isn’t driven often, get an intelligent battery minder/tender to keep the car battery charge up.
If situation continues, you have a battery drain somewhere. Pull fuses until you see current draw is low approx. 150mA
99xk8guy
Sep 29, 2025 10:51 PM
pdubay
Mar 28, 2019 04:20 PM
powerlord
Oct 21, 2016 07:14 AM
wesmc2
Feb 14, 2013 03:03 PM
dennisw
Nov 11, 2011 11:56 AM
