Restricted Performance
Old Nov 18, 2009 | 07:42 AM
Raheny's Avatar
Default Restricted Performance
Hi All,
Have had Restricted Performance flickering on the dashboard for the past 10 days. Got the codes read and it appears to be a knock sensor failure. Has anyone had a similar issue? Easy to replace?
Thanks,
Jonathan
Old Nov 18, 2009 | 08:32 AM
Gus's Avatar
Gus
Yes I did! Go to my page and see my write up on my restricted performance issue. It was a royal pain in the you know what. You were lucky to get the code.
Old Nov 23, 2009 | 04:01 AM
Raheny's Avatar
Thanks, Gus. A very informative account of your efforts. Glad you got it sorted.
Old Dec 2, 2009 | 07:10 PM
Raheny's Avatar
Update: So, I had the faulty knock sensor replaced with a second-hand sensor (tested to make sure it was working OK). Drove for about 15km and all was fine. On the drive back, only about 2 minutes after starting the engine, the RP message came back and flickered on and off for the remainder of the trip. It's been flickering on and off since then, though not as frequently as before I has the the sensor replaced. Very furstrating. Having the ECU codes read tomorrow and investigated. Any thoughts?
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
1100me
Oct 1, 2015 11:49 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
