Restricted Performance / Coolant Leak
Old Aug 28, 2025 | 01:53 AM
Ginagee0605's Avatar
Default Restricted Performance / Coolant Leak
Hi, looking for further advice.
Trying to fix my dad's 2000 xk8. Car was running and driving fine, however had a coolant leak due to split thermostat housing, which has been replaced, but since then the car wouldn't start, changed the battery and knock sensors as that came up on the fault codes, but it starts but in restricted performance mode, miss firing and it will idle but as soon as you touch the throttle it cuts out.
Any ideas what could be causing this? What else would a coolant leak affect? No more codes are appearing either. Thank you!
Old Aug 28, 2025 | 03:17 AM
RichardS's Avatar
Since it is running in restricted performance mode, I'm sure that there must be a code being generated. Which scanner are you using and can you see the live data?
Richard
Old Aug 28, 2025 | 06:50 AM
zray's Avatar
Did you do a hard reset after replacing all those parts ? That often helps the various “brains” forget about their meltdown, and start with a clean slate.
Z
Old Aug 28, 2025 | 06:51 AM
JaagXKR's Avatar
Maybe some coolant or water in the spark plug holes? Did you wash the engine?
Ginagee0605
XK120 XK140 XK150
Aug 27, 2025 07:09 PM
SJ9809
Aug 29, 2022 10:42 PM
perfwise
Apr 27, 2022 02:47 PM
vedp
Nov 29, 2021 02:18 PM
Brit-Type
US Northeast
May 11, 2021 12:48 PM
