XK120 XK140 XK150 1948 - 1962
Restricted Performance / Coolant Leak
Old Aug 16, 2025 | 11:00 AM
Ginagee0605's Avatar
Default Restricted Performance / Coolant Leak
Hi, looking for further. advice
Trying to fix my dad's 2000 xk8. Car was running and driving fine, however had a coolant leak due to split thermostat housing, which has been replaced, but since then the car wouldn't start, changed the battery and knock sensors as that came up on the fault codes, but it starts but in restricted performance mode, miss firing and it will idle but as soon as you touch the throttle it cuts out.
Any ideas what could be causing this? What else would a coolant leak affect?
Thank you!
Old Aug 27, 2025 | 07:09 PM
Fraser Mitchell's Avatar
You've had no responses because you've posted in the wrong forum. If you look at the forum title, you'll see it's for the sports cars built between 1948 to 1962 Post in the X100 forum: -
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
Ginagee0605
Jun 20, 2025 02:41 AM
1sloXJR
Aug 17, 2021 09:01 AM
DallasJagBoomer
Oct 15, 2018 09:24 AM
coisty
Nov 2, 2013 06:26 AM
black vanden plas
Oct 22, 2010 11:34 AM
