Retracting side mirrors
Old May 25, 2021 | 06:49 PM
MsMaybe98's Avatar
Hi all,
I checked my mirrors (98 XK8 Convertible). Found the neutral position of the selector switch and pulled the joy stick back for about 15 seconds. Nothing. I manually folded the mirrors again and they became easier to move. Seemed there is a spring loaded detente to keep the mirror either folded in or folded out.
Old May 26, 2021 | 05:41 AM
xk810024's Avatar
Hi, Thanks for this. I tried that too and ... nothing. Auto would be so nice (especially in NYC!)
I will have to try again to fold them in manually. They really seem stuck though!
Old May 26, 2021 | 06:43 AM
SamtheSham's Avatar
Originally Posted by MsMaybe98
Hi all,
I have the exact same situation on my '06 mirrors. Several in the forum seem to think the electric folding is a 'standard' option. My '06 is a Victory Editin, so I would think little was deleted.
Now to try to lock them in place for when they are in the wind slip stream.
Old May 26, 2021 | 10:05 AM
MsMaybe98's Avatar
Good morning!
A little lubricating spray would probably help. Having lived in the City (financial district) for many years, I fully agree.
Old May 28, 2021 | 07:15 AM
xk810024's Avatar
Thanks! turns out I just had to slightly change the angle of how I was doing it and they folded in just fine. Yeah, fingers crossed she stays ok on the UWS!
Old May 29, 2021 | 09:42 PM
bcprice36's Avatar
Mirror Men & Lady,
I have never seen a Folding Mirror on a XK8 or XKR! I've heard of it but never have ever seen one! If you have an XK8 or XKR with them Please send a Photo! I'd just like to say I've seen one with Folding Mirrors........All I can do is move the Right Hand Mirror by using the little Joy Stick when I am backing up.....It dips when I Pull the joy stick while in Reverse! But I have never seen a Folder.....
Billy Clyde @ Cinco Ranch
Old May 30, 2021 | 06:51 AM
SamtheSham's Avatar
I was 'playing' with my mirror switch a few days ago, and heard a 'click' and saw a little movement in my retract mode. I dug out my papers and found the original 'Window Sticker'. It lists folding mirrors as one of the specs for the "Victory Edition". Now I have to go in and see if I can determine why the mirrors will not fold.
Old May 30, 2021 | 08:02 AM
  #28
astromorg's Avatar
Here in UK, most parking lots are still marked out to a standard introduced for cars of the 60s and 70s so they're a bit tight for more modern vehices. This makes folding mirrors a great addition. Even better is to arrange for them to fold on locking the car and unfold when unlocking, so I have designed and built a module for each mirror to do just that.
This video shows mine folding on Double Locking (two presses - one to lock, another to deadlock) and unfolding on Unlock. Normal fold/unfold using the joystick is unaffected by this additional arrangement
Old May 30, 2021 | 08:39 AM
JimmyL's Avatar
I have heard of folks retro-fitting the "power fold" mirrors here in the states, but I don't think I've heard of a car over here coming with them.
Old May 30, 2021 | 10:06 AM
  #30
bcprice36's Avatar
Now Astromorg! --- Isn't that neat? My 2005 does not have them...only the Right Mirror Dips when in reverse...I like it!
Billy Clyde @ inco Ranch.
Old May 30, 2021 | 02:31 PM
  #31
MsMaybe98's Avatar
Astromorg,
Very nice! That would be a great option for both mirrors here in the states. Few people are careful as to how close they get to another vehicle while passing and / or parking. Was it difficult to construct?
Old May 30, 2021 | 05:31 PM
  #32
SamtheSham's Avatar
Just got mine to start folding using the 'Joy Stick'. Have not tried the key fob yet. Will lube well and see what happens. Seems to need brakes applied to work???
Old May 31, 2021 | 12:54 PM
  #33
astromorg's Avatar
....... Was it difficult to construct?
The designing of the autofold modules was certainly the most difficult part, Construction OK if you're handy with a soldering iron and making stripboard circuits. Fitting required seven wires from the new module (One module per door/mirror) to be spliced into various wires from the door module. The problem for you with my design is that it utilises the UK Double Locking system that I don't think is fitted to US spec cars. That could be an awkward aspect requiring a rethink!
Mirror folding is meant to be independent of the braking system. Folding by using the fob is not possible without fitting a custom designed module to each mirror system as mentioned above.
Old May 31, 2021 | 07:37 PM
  #34
NorXKR's Avatar
My 2000 XKR has dip mirror in reverse, and a center position on the switch, but does not fold. Do all have manual folding mirrors? Mine is stuck and I dont want to destroy them......
Old May 31, 2021 | 08:29 PM
  #35
MsMaybe98's Avatar
Astromorg,
I can imagine the design phase was the most time consuming. I can handle a soldering iron and design / build simple stripboard circuits ok. I am not familiar with the UK Double Locking System though. And since my mirrors are manual, I would have to basically add the Jaguar motors, gears etc or just replace the whole mirror units with the electric folding ones. Would love to have the electric folding option.
Old Jun 1, 2021 | 06:58 AM
  #36
SamtheSham's Avatar
After retracting my mirrors, I wiped down the inside of the 'fold'. Pretty dirty, but I also found some type of rubberized material along the leading edge, and also on the bottom. Do not know if this was supposed to be there or not.
Old Jun 7, 2021 | 06:08 PM
  #37
Ledmi's Avatar
Default Don’t close manually if you have electric option
It is well explain in the owners manual « do not close manually, it might damage the mechanism »
If you have the electric folding option avoid any manually folding operations.
READ your manual first, it is well explain.
Michel
Old Jun 7, 2021 | 06:15 PM
  #38
SamtheSham's Avatar
I think that might have been the problem with my mirrors. They had been manually folded(before I got the car.).
Old Jun 7, 2021 | 07:10 PM
  #39
bcprice36's Avatar
Sam and All,
I tried my Mirrors manually and they break back over a little hump and Close...You could do this at any time but MANUALLY! Didn't hurt the Reverse drop at all...So I guess everyone has Folding Mirrors,, Just not automatic Folders.....
Ter11
Aug 3, 2019 12:39 PM
ItChief67
Feb 27, 2019 09:35 AM
frankc
Feb 17, 2015 08:38 AM
djsaroe
Mar 24, 2013 08:52 AM
nick hudd
Mar 2, 2010 09:30 PM
