Retro fitting the cabin pollen filter.
Old Mar 25, 2012 | 08:27 PM
Abby's Guy's Avatar
[quote=tommyzr;487673]I think after looking at the pictures & reading the proceedures that takes 4+ hours to do, I will have the dealer's shop do this job. Paying $150. - $200 isn't bad & they know how to do it .... I hope!
Maybe...The dealer here ordered the filter, charged me for it, then discovered there was no holder for it. Said it had apparently been removed and no parts houses they contacted had one. Oops.
Old Mar 26, 2012 | 09:18 AM
Jon89's Avatar
Jaguar Corporate customer service says that our 2006 XK8 has a cabin filter. Brutal says that it does not and that cabin filters were not installed on the XK series until the 2007 model year. I'm not going to pull the cowl just to look for it. I'll take Brutal's word over Jaguar Corporate....
Old Oct 7, 2012 | 04:25 PM
stevepaa's Avatar
no need to remove the wide plate. and when you unscrew the wiper assembly, just rotate it as you remove it and lay it on the engine area.
the left hand box is still available.
I replaced the sealing pieces on the watershield.
did this in under 2 hours.
Old Oct 8, 2012 | 07:27 AM
dennisw's Avatar
Originally Posted by hlgeorge
If I can't open a cover and replace a filter, mine is not getting one!
I agree..the person that put this filter here must have been on crack..
I can live without it
Old Jan 11, 2013 | 08:12 AM
Tony S's Avatar
Originally Posted by Jaxkr
You are correct the car should be reprogrammed, it is a simple thing to do.
Jaxkr,
Been quite a while since I installed the pollen filter assembly, but I still haven't been able to re-program the cabin fan to up the fan speed.
Do you happen to have a basic procedure, using the WDS / IDS, on which module controls the fan speed and how the re-programming is carried out.
Many thanks in advance.
Old Jan 11, 2013 | 04:39 PM
stevepaa's Avatar
Took mine to local independent to reprogram. no charge!!
Old Jan 11, 2013 | 06:48 PM
xenophobe's Avatar
You used the LHD filter holder?
Old Jan 11, 2013 | 06:54 PM
  #28
stevepaa's Avatar
yes
aholbro1
Dec 29, 2024 06:46 PM
xjrjag
Oct 24, 2024 03:09 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
Saturbo
Sep 8, 2015 07:35 PM
