The Scent of a Jaguar
Old Jan 10, 2018 | 04:39 PM
StuG's Avatar
Both of my Jaguars smell from oil, petrol and leather. It's exhilarating!
Old Jan 10, 2018 | 08:17 PM
Terrific's Avatar
Default Mldew
Almost all of my Jaguars have had this smell. Mildew in the heater / ac ducts causes same smell. I have sprayed copious amounts of Lysol in the cowl intakes which will take some of it away for awhile. I don't know if one could ever get rid of all the small underhood leaks. The smell seems to be worse inside the well sealed body than under the hood ???
Old Jan 10, 2018 | 10:11 PM
CE2 JAG's Avatar
Originally Posted by wabisabi
Yes, it was the valve covers leaking just a tiny bit, just enough to stink up the car!
After 3 changes, it has been oder-free since last June. The smell seemed to be coming
thought the vent system, though -- not from under the center console. But from what
I've read, it's usually the valve covers. Check really carefully to see if there is a small
leak. Good luck!
Thanks WabisabiI’m getting the trans fluid flushed and checking for valve cover leaks soon.Although the car doesn’t drip any oil, I was able to find some oil or ATF back in the tunnel just above the cat
Old Jan 11, 2018 | 05:48 PM
jimmiejag's Avatar
I replaced my cam cover gaskets as one of the first projects on my Jaguar, just after plastic cam chain tensioner replacement. In spite of that, I still have a slight leak on both sides. I found that the burnt oil smell in the cockpitof my XK8 coupe, from the leaking cam covers, can be minimized by holding the re-circulation button until it beeps. Unfortunately, you will have to hold it in each time your start your XK8, but it really helps.
Mine is a 1999, so I don't know if all X100s HVACs function that way.
Old Jan 13, 2018 | 09:17 PM
CE2 JAG's Avatar
My issue seems to be different that most - I don't get any smell through the HVAC. It blows fresh.
The burnt smell comes from the very backside of my center console.
I'm still having my valve cover gaskets checked. Should be able to see any signs of leaking once it is up on a lift. Having just purchased my Jag, I don't even own jackstands or ramps yet. Given the cost of a good mechanic, I'll probably set up shop soon!
Old Jan 18, 2018 | 02:01 PM
johns427's Avatar
When I replaced the right side cam cover after the tensioner upgrade, I decided to use a thin coating of black RTV on the sealing surfaces and a new gasket, and this seems to work. Now I have to go back and RTV the left side cover. I used "Great Stuff". The smell and heat entered from under the center console so I stuffed the rather large gaps with rubber foam insulation. I never owned a car with so many flaws, but I love it.
Old Jan 28, 2018 | 02:29 PM
frankc's Avatar
I miss all this. After an operation some years ago I lost 90% of sense of smell. People are always telling me how nice the leather smells etc. I think I am loosing out.
Jaguar Forums Editor
Jaguar Press release
Jan 12, 2016 11:14 AM
Rocky15
Dec 30, 2015 06:48 AM
HavocX10
Dec 28, 2015 09:43 PM
OMGPirate
Motorsports
Dec 16, 2015 09:21 PM
uncheel
Dec 15, 2015 06:37 PM
