Seat Belt Buckle help needed
Old May 5, 2015 | 02:46 PM
RaceDiagnostics's Avatar
Default Seat Belt Buckle help needed
I need to replace the wiring going to my buckle as I have a 5-1 flash code.
I tried using moderate force to split apart the two sides of the clam shell but no joy.
Does anyone know a good technique to split it without damaging it?
Old May 6, 2015 | 12:45 AM
jamdmyers's Avatar
Are you sure it's within the clam shell... many of these are due to the connectors under the seat?
Old May 6, 2015 | 02:46 AM
....... or the Hall Effect sensor in the buckle.
Have you tried just cleaning it with a compressed air aerosol and/or solvent spray?
Old May 6, 2015 | 03:15 AM
I had the seat out yesterday to get a good look at it again, it is not the connector as I took that apart and gave it a clean. I will give it a blast with compressed air and see if that helps.
If not I will just need to force the shell off and rewire, the fault is intermittent and "feels" like a wiring issue.
Old May 6, 2015 | 06:14 AM
cjd777's Avatar
RD, I wait on your solution, as I have tried everything short of taking it apart. I have the 5 2 and can't see a wire connected to the buckle. Had the seat out on two occasions with no luck getting the light off.
I have learned to ignore it, but she who must be obeyed, "why it that light still blinking", has put it into a different priority.
Wayne
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
