Seat Control Module
Old Jan 13, 2011 | 07:03 PM
test point's Avatar
Default Seat Control Module
Been snowed in all week and decided to fix one of the postponed little issues. We seldom move the passenger seat and only discovered that it would not move a few months ago. It did work at one time in my ownership and had a '05 date so it has been replaced before.
Fuses #1 and 8 are good. Removed the module and opened it looking for the case damaged edge printed circuit. Found some blue/green corrosion at the Z1 diode at the suspect edge and it appears that it is open in both directions. Best I can tell the printed circuits lines are not damaged as I get continuity using sewing needles clipped to a VOM.
Haven't got a response from a car-parts.com query.
Anyone know of one of the module repair folks that might repair the seat module?
Old Jan 13, 2011 | 09:49 PM
motorcarman's Avatar
I think you can swap Driver's/Passenger's to check for proper operation. Back in the late 1990s and early 2000s I remember having to configure the replacement passenger seat modules in the driver's harness because the WDS would not recognize the passenger seat module. I called Tech Line and was advised to install it in the driver's seat, configure it and reinstall it in the passenger seat.
Swap modules side-to-side and see what happens.
bob gauff
Old Jan 13, 2011 | 09:53 PM
I found an early TSB that does not apply to your car but is info.
bob gauff
Old Jan 15, 2011 | 05:50 PM
test point's Avatar
Bob, thanks for the TSB. I put all your TSB posts in my Jaguar library.
Pulled the driver module today and the passenger seat works fine with it so the problem is clearly the module. While I had both out noticed that the VCAT extension was /100 on one and /400 on the other. I know the passenger module worked at one time in my ownership. Thought they had to be matched or can they be programmed by WDS / IDS? Both modules had dates much later than the car's manufacture date so both had been replaced by a PO.
I have replaced one on another Jaguar from a wreaking yard with a matched number and it was plug and play. Will it be if I find a mismatched /XXX extension? I have also replaced one on another Ford car for about $35. My module says Ford, made in Spain on it. Any chance of finding a Ford part match?
Old Jan 19, 2011 | 05:49 PM
xjrguy's Avatar
test point,
Modules for XK8's through 2002 were not programmable in the field, that commenced in 2003. The/XXX suffix is the specific software level programmed at the factory for market and application; i.e. RH, LH, Memory Seat, Non-Memory etc. To assure correct operation, you'll want to get a module with the correct suffix.
Cheers,
Old Jan 19, 2011 | 05:59 PM
test point's Avatar
Not programmable?
How do my two modules function with different /XXX extensions?
It would greatly expand wreaking yard searches if I could ignore the extension.
Old Feb 4, 2012 | 07:07 PM
Gary Horton's Avatar
Looking for a repair or replacement on a 2004 XK8 seat control module - passengers side. Model lje2160ab/xxx. Any help out there?
Thanks,
Gary
Old Feb 5, 2012 | 12:37 AM
test point's Avatar
Try car-parts.com
They distribute your parts request to hundreds of yards who will then respond directly to you. Many, however, have an auto response whether they have the part or not. Waste of your time and theirs.
Steviedee1st
Nov 28, 2023 06:32 PM
XJsc-guy
Sep 25, 2015 11:09 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
jaguarbill
Sep 5, 2015 11:43 AM
