Seat Rail Trim Removal - RESOLVED
Old Mar 2, 2021 | 10:09 AM
TropicCat's Avatar
Question Seat Rail Trim Removal - RESOLVED
How do you remove the trim covering the mounting rail for the seat?
Last edited by GGG; Mar 9, 2021 at 05:28 PM. Reason: Add "RESOLVED" to thread title
Old Mar 2, 2021 | 12:51 PM
RJ237's Avatar
It slides forward.
Old Mar 2, 2021 | 12:55 PM
Dr. D's Avatar
Mine just slide forward out of their detents without the use of any tools.
Old Mar 2, 2021 | 12:59 PM
Jon89's Avatar
^^ Yep....
Old Mar 2, 2021 | 01:47 PM
The trim has 2 square slots:
which engage with metal "tongues" on the rail (front one arrowed):
Slide forwards to release. It should NOT take much force to release.
Old Mar 2, 2021 | 02:07 PM
michaelh's Avatar
Not relevant to the OP's question, although that looks more robust than the previous incarnation fitted to my 98.
That has a strong spring clip at the front that has to be lifted just free, then the assembly has to be slid backwards to clear the rear attachment to the rail. Possibly Jaguar had issues with them rattling or something, as there was also a really strong double-sided adhesive pad stuck at the red outline:
The rear attachment is a superbly under-engineered pair of plastic tangs that break off. I used a small piece of ABS glued in as a repair:
Old Mar 3, 2021 | 09:57 AM
ccfulton's Avatar
If the seat is height adjustable (some are not), I find it is easiest to install and remove it with the seat bottom at maximum height.
Old Mar 5, 2021 | 09:42 AM
TropicCat's Avatar
Thanks. Info VERY helpful. I'll give it another try. I pulled it forward with what I thought was enough force to release any plastic clips but when it wouldn't release I was afraid pulling forward was NOT the way to release it. I'll give it more force and hope the clips don't break.
Thanks for the help.
Old Mar 9, 2021 | 11:44 AM
TropicCat's Avatar
Thanks for the help. I did finally get the trim to release. It took a little more force than I thought it should but it finally came free. I got the seats out and replaced both of the seat belt latches. Which was the original objective. But I also learned that I might be able to fix both of the headrest cables so ... maybe they'll be another thread when I give that a try.
Thanks again.
wesyoung
Sep 19, 2020 10:50 AM
Johnken
Dec 11, 2018 01:23 PM
coastaljag98
Apr 25, 2013 04:44 PM
danog
Dec 4, 2012 04:00 PM
JagXK82001
May 12, 2011 10:37 PM
