Seat switch holder
Old Oct 24, 2014 | 05:25 AM
mrobinson's Avatar
Default Seat switch holder
Hi,
A few weeks ago I replaced the switches on my drivers seat, but in the process I must have broken the screwed-in part behind it as it won't stay clipped in.
Anybody know what this part is called and/or a product code so I can order a new one ?
Old Oct 24, 2014 | 08:26 AM
Poppyboy's Avatar
I did the same. There's a clip on one side which breaks off. I'm considering alternatives today (rubber band, Velcro, etc.). The broken clip is connected not to the seat switch, but to the seat switch housing, residing inside the seat.
Old Oct 24, 2014 | 08:50 AM
WhiteXKR's Avatar
The housing is not available separately, it is part of the seat assembly. It is possible to repair by drilling a hole above and below where the plastic catch strip broke and inserting a piece of heavy wire to replace the broken plastic catch. The ends of the wire can just be bent over to keep it in place.
Old Oct 24, 2014 | 01:35 PM
Poppyboy's Avatar
I used some high quality Velcro, which I placed on the broken side. Seems to be holding well on the passenger side. So-so on the driver side.
Old Dec 21, 2015 | 01:49 PM
MarkVIII's Avatar
Are the seat switch housings still not available? Both driver's and passenger side on mine are broken. The driver's one was broken badly by the previous owner's hack mechanic. I just broke a small piece off of the passenger one.
I'm not sure wire, velcro and/or zip ties will hold them in securely.
Thanks!
Ken
2003 XK8 Vert
Old Dec 21, 2015 | 02:02 PM
MarkVIII's Avatar
I was able to find 2-seat control switch housings on E-Bay UK!! Not cheap (80-pounds for both), but the should hold my dangling seat controls in place!!
Jaguar should make that part separately! It was pretty brittle on the passenger side, the one I broke, and I was pretty careful removing it. The driver's one was broken in a bunch of pieces.
Ken
2003 XK8 Vert
Old Dec 21, 2015 | 02:05 PM
WhiteXKR's Avatar
Thanks!
Ken
2003 XK8 Vert
They were never available separately. Occasionally you can find a used one on ebay such as : Seat Switch Housing Mount Front Right Jaguar XK8 XKR X100 1996 2006 | eBay
Old Dec 23, 2015 | 11:42 PM
jshaub's Avatar
I have both sides available. If interested send a PM.
Old Dec 27, 2015 | 12:17 PM
fdbrock's Avatar
Default DIY Fix - Illustrated
With some trial and error, and slight modification of Gus' wire method, I recently completed repair for the broken clip on my passenger side seat switch housing.
The photos below illustrate the process:
Front view showing wire clip installed. I used 12 gauge copper wire. 14 gauge would likely work as well, but I wouldn't recommend anything smaller.
After forming the clip for correct width and height to securely hold the switch pack, I drilled two holes (~3/16") through the bottom of the housing, just to the right of the broken plastic clip. The new wire clip is inserted from the bottom, and the slightly flattened ends are folded over and down against the bottom of the housing cup.
This view shows the installed clip from the bottom side of the housing.
Close-up view from the bottom with the switch pack installed. You can see how the ‘loop’ of the wire clip grabs the prongs of the switch pack to hold it in place.
I hope this helps someone save some bucks...
Rivguy
Nov 13, 2022 02:55 AM
multijag
Sep 14, 2015 04:54 PM
Clamdigger
Sep 12, 2015 03:43 PM
jagent
Sep 12, 2015 09:10 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
