Second assistance request
Old Feb 21, 2014 | 10:15 AM
Berdes's Avatar
Default Second assistance request
Just noticed how fast and badly the brake disks on my wife's XK8 rust.
Are there alloy disks available that would work and not rust like these?
Or should I just spray them with CRC like my sister-in-law did
(lord rest her poor soul) ?
Old Feb 21, 2014 | 12:06 PM
test point's Avatar
Driving occasionally will take care of the rust.
Old Feb 21, 2014 | 12:12 PM
(I'll assume this is a serious question)
Regular brake discs are steel and light surface rust is common wet areas after the vehicle has been standing for a while. It should easily clean up with running the vehicle a short distance.
Pitting or heavy surface rust could be an indication the calipers are not moving freely.
No lubricant of any kind should be used on the disc faces. It will seriously affect braking.
Old Feb 21, 2014 | 12:29 PM
Jon89's Avatar
Agreed. Just drive it. That will keep the brake rotor rust at bay. As previously advised, do not spray any chemicals on the rotors. That's a severe safety hazard....
Old Feb 21, 2014 | 03:41 PM
Berdes's Avatar
Default brakes
Well, the first part was serious anyway. The disks do get some surface rust much more rapidly than is apparent on the other vehicles in the driveway.
The note about my sister-in-law was of course in jest. However, her mechanic did ask her one time if she wanted the brakes greased while he was doing the seasonal air change in her tires. (true)
Old Feb 21, 2014 | 07:40 PM
The mechanic gets the last laugh on that one.
Caliper pins / pad backplates on disc brakes and expanders on brake shoes do need special high temperature brake grease. So does the Yoke on an XK8/XKR handbrake.
Old Feb 21, 2014 | 09:37 PM
Paul Pavlik's Avatar
I used to drive Dealer Trade Cars for a Cadillac Dealer. Some brand new cars had rust on the Brake Discs resulting in a Pulsing Brake Pedal.
This was known as "Lot Rot" and required re-finishing during New Car Setup.
Old Feb 22, 2014 | 03:21 AM
Originally Posted by Paul Pavlik
........... known as "Lot Rot" ........
Old Feb 24, 2014 | 07:50 AM
oldmots's Avatar
Jaguar OEM brake disks are ductile iron and are going to rust fast outdoors. As was said, driving will remove it.
1964Daimler
Oct 3, 2015 12:18 PM
LilaJagHubby
Oct 1, 2015 01:47 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
