sensor malfunction
Old Mar 25, 2015 | 08:24 AM
Johncolucci3's Avatar
Default sensor malfunction
I have a 1999 XK8. When I get out ( every thing turned off, keys in hand) the car gives a constant ding, ding like you left the keys in, or lites on. When I shut the door, ding quits, but when I try to use the remote lock, or trunk release, I get an audible alarm and fob won't work. It seems like there is some sensor that is malfunctioning thinking some thing is still on, or key left in ignition. Any thoughts?
Old Mar 25, 2015 | 08:34 AM
John - I've moved your post from the General tech section to the XK8/R specific section where you will get a better response.
When you remove the key - check that the little door on the key slot closes - sometimes just a gentle tap on the bottom of the steering wheel will free it. If sticking a drop of machine oil or squirt of wd40 will fix
Old Mar 25, 2015 | 08:35 AM
motorcarman's Avatar
I was typing an answer when the post got moved and I could NOT find it!!!!!!!!!!!!!
bob gauff
Old Mar 25, 2015 | 08:36 AM
As I posted before and this disappeared.......................
The 'KEY-IN-IGNITION' lock barrel flap is probably STUCK!!!!!!!!!!!!!!!!
bob gauff
Old Mar 25, 2015 | 08:40 AM
Sorry Bob - looks like I moved as you were typing
Old Mar 25, 2015 | 04:11 PM
wolfpck1's Avatar
also see if the car is in valet mode its easy to accidently hit it with your knee getting out ...lock and unlock the drivers door manually to come out of valet mode .
Old Mar 25, 2015 | 08:35 PM
That was a strange thing!!!!!!!!
I typed an answer and when I submitted it, the post stated something like post not found contact admin if the problem persists.
bob gauff
Poet
Feb 7, 2025 02:18 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
leep123
Sep 30, 2015 03:41 PM
Doug S
Sep 30, 2015 02:03 AM
