"Set the bonnet to the service access position"
Old May 31, 2010 | 08:12 AM
itspec60's Avatar
Default "Set the bonnet to the service access position"
I have seen this referenced in the JTIS. Is there another position for the hood? It would be nice to have a little more room to work. Thanks
Old May 31, 2010 | 08:49 AM
itspec60's Avatar
I should have done a search on the forum before asking the question. I found the answer. Thanks
Old May 31, 2010 | 09:15 AM
2002XK8Orlando's Avatar
...,and that answer is? Just curious as I have wondered as well but couldnt find anything when searching
Old May 31, 2010 | 09:19 AM
H20boy's Avatar
nice itspec, I was about to give you the instructions. Proceed with the engine bay access...
Old May 31, 2010 | 01:02 PM
SeismicGuy's Avatar
Me too--is there an FAQ link for this?
Doug
Old May 31, 2010 | 01:24 PM
itspec60's Avatar
found this inside the forum...raising the hood to its "service position" which is nearly 90 degrees vertical. Do this by removing the support pistons and inserting one each bolt on either side of the front hinge location. It looks precarious, but is actuall quite stable if you are not outdoors [in the wind].
Old May 31, 2010 | 01:40 PM
Thanks!
Old May 31, 2010 | 05:47 PM
SeismicGuy's Avatar
I sort of knew that but still was not sure how and at which end to remove the support pistons. It looks like these are ball-and-socket fittings and I was afraid to force them.
Doug
Old May 31, 2010 | 06:48 PM
test point's Avatar
They just pop off. Just don't drop the hood!
Old Jun 1, 2010 | 03:43 PM
SilverXJ's Avatar
Damn... I could have use that this weekend and my head would have thanked me. I had thought about releasing the dampers as the hinge does look like it is setup for this.. but I didn't have time to fool with if it didn't as well was a bit worried about having the hood coming into contact with something it shouldn't.
Actually I would prefer a "service access position" for the engine/suspension. Bending over it this whole weekend was not the most comfortable thing for my knees.
Old Jun 1, 2010 | 05:14 PM
Brutal's Avatar
Doug, unclip the bottom of the struts, then they swing out of the way when verticle
trosty
26
Dec 18, 2022 06:40 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
teacoff
Sep 10, 2015 08:25 AM
bdboyle
Sep 4, 2015 06:16 AM
