Side mirror rocker switch on '99 XK8
Old Aug 25, 2022 | 03:30 PM
XK8WGM's Avatar
Default Side mirror rocker switch on '99 XK8
I did some searching and found a thread from 2014 that suggested the rocker being "frozen" and not able to move would be a physical issue, not electrical. I am in a hot climate, so it cannot be the extreme cold temperatures others suggested.
If it is a physical issue, would I be able to spray a small amount of WD-40 into the rocker switch area and have some good results? Do you see any potential issues with doing this?
Old Aug 25, 2022 | 07:04 PM
Johnken's Avatar
Wd40 is non conductive, its just plastic and a circuit board in there.
Something is jamming up a sliding plastic assembly. Heres an idea, use it if you choose it: take your palm sander. Turn it on, hold it upside down rest the smooth plastic top of it against the rocker switch area. That thing is vibrating a few thousands of times a second, perhaps it'll jiggle the assembly free.
Just 2b clear sander pad is facing up not touching anything. Sounds like a quick free try to me Wayne.
John
Old Aug 26, 2022 | 08:15 AM
XK8WGM's Avatar
FYI, I went out this morning and sprayed a tiny bit of WD40 into the slot next to the left/right rocker switch for the mirrors, clicked back and forth, and it is now working. It felt gritty at first but cleared up.
Old Aug 26, 2022 | 09:15 AM
Johnken's Avatar
:-) Nice Friggin job!!!
John
brinny
Mar 22, 2022 03:01 AM
jomo
May 27, 2019 12:19 AM
Ltd
Apr 20, 2019 09:23 PM
East Haddam
Mar 5, 2014 12:21 PM
Skid Mark
Jan 11, 2012 06:50 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
