Solar Battery Charger
Old Nov 8, 2011 | 10:52 AM
Gus's Avatar
Gus
Default Solar Battery Charger
Winter is around the corner and I do not have a garage and wanted to keep my car batteries fully charged now that the cars are not used every day. After much searching I found this Solar Panel at Harbor Freight 1.5 Watt Solar Battery Charger The price was right and the specifications 1.5watts seemed just what I needed. This is how I installed it in my cars Solar Battery Charger
Old Nov 8, 2011 | 01:18 PM
The Coupe's Avatar
Interesting...thanks for posting that up.
Now go do a how-to on building a garage!
Old Nov 8, 2011 | 02:01 PM
Gus's Avatar
Gus
I am working on that.
Old Nov 8, 2011 | 08:20 PM
Brutal's Avatar
lol. I use that same one through the power port on my truck. It stays hot when key is off which is the only requirement
Old Jun 4, 2021 | 01:54 AM
david056's Avatar
Are solar battery chargers worth buying?
Old Jun 5, 2021 | 02:08 AM
david056's Avatar
Are solar battery chargers worth buying? and what about other side of the story? We don't always have sun shining sometimes there is off gridcloudy and rainy weather too, what will we do in this kind of weather ?
Old Jun 5, 2021 | 03:15 AM
kevh's Avatar
Unless it's dark then you have sunlight & sunlight = solar power
Old Jun 23, 2021 | 07:37 AM
Ron62's Avatar
I sticked one permanently at the back seat of the convertible and hooked it to the battery. Great thing. Never have battery problems anymore.
Old Jun 23, 2021 | 05:46 PM
eliotb's Avatar
Ron: did you have to get a “controller” or something like it to keep the battery from overcharging? If so, have you got a brand suggestion? I’m looking to do the same for my ‘03 XJ VDP which isn’t driven as often as it should be. I don’t have a garage and am leery of running a power cord across the common sidewalk to a charger to guard against a liability issue.
Thanks in advance.
Eliot
Old Jun 24, 2021 | 01:18 AM
Ron62's Avatar
Eliot, The power delivery is enough to keep the battery into shape. It is a trickle charger that doesn't need to be unplugged when you go for a drive. The amount of current is keeping the battery healty and the alarm is working. It automatically stops when the battery is full so overcharging is no issue. I got mine from Westfalia. https://www.westfalia.eu/nl/shops/au...ne-energie.htm
Swagguar
Sep 30, 2015 01:34 PM
oldjaglover
Sep 29, 2015 03:27 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
Jzar
Sep 27, 2015 02:55 PM
