Spider hose
Old Dec 11, 2014 | 03:11 PM
sgparnes's Avatar
Default Spider hose
What is the technical name and/or part number for a "spider hose"? I think it is a lower radiator (heater?) hose between the block and heater. I have a slow coolant leak and was told it is from there. Hard to get to? '01 XK8 4.0
Old Dec 11, 2014 | 03:35 PM
brgjag's Avatar
octopus hose?
Old Dec 11, 2014 | 03:40 PM
cjd777's Avatar
https://images.search.yahoo.com/imag...s&fr=yfp-t-250 Yeah, BRG hit it. Have a look at this.
Wayne
Old Dec 11, 2014 | 03:47 PM
brgjag's Avatar
I just did this hose replacement this past late summer. FUN job. ha ha ha
it can be done at home with basic tools, just ganna get some scuffed up knuckles before you are done.
On the drivers side of the hose, there is a plastic "T" like connector, replace it while you are at it, cheap part. DON'T buy this parts from a DEALER, they are out there on Ebay or parts suppliers listed on this site. As far as I know the hose is the same for all years 97-2006 I believe.
Old Dec 15, 2014 | 12:58 AM
Sentinelist's Avatar
Is the octopus/spider hose the only coolant hose under the throttle body, behind the engine? That's where my leak is coming from. I've already replaced the two coolant hoses under the supercharger earlier this year.
Old Dec 15, 2014 | 03:28 PM
brgjag's Avatar
I don't have a SC XK8 but mine had a coolant line from the pass side tube that the valley hose/octopus hose connects to that runs to the EGR, then another from the EGR to the TB. Then of course as you know the octopus hose, then the two heater core lines, then the coolant hose from the TB to the T connector that the octopus hose connects to and the other valley hose connects to the same T on the drivers side.
That said, it may be all diff for your car being a SC car.
Old Dec 15, 2014 | 07:10 PM
michaelh's Avatar
If you've done the valley hoses then you've done the worst (or at least the most laborious) bit. The octopus is buried under the TB, although I've heard that some have managed to replace it without removing the latter. Beware of the cable tie that holds it in place. As the others have stated it does have a few connections and the 'T' piece attached to the octopus on one side can fail. Best to change what you can while you're in there so you don't loose all your knuckle skin. I removed the electrical connectors that are attached to a plate fixed on the top of the transmission to ease access. It took a little longer but unless you're 7ft or more tall its a stretch.. HTH, Mike Sorry no paragraphs; still having issues with text formatting
Old Dec 15, 2014 | 08:12 PM
brgjag's Avatar
Yea you will have to remove the TB.
Old Dec 16, 2014 | 12:09 AM
As I'm going to be crunched for time for the next couple months... this sounds like a job for motorcarman! I may be in touch soon to catch up on a few items.
aode06
Jul 28, 2023 02:26 PM
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
