Sport mode light will not go out
Old Jul 5, 2014 | 11:53 PM
rednax's Avatar
Default Sport mode light will not go out
I used the sport mode today just for fun and when I pushed the button to disengage it, the light would not go out. I tried it several times and also shut down the engine and restarted it with no luck. Anyone have a similar problem or better yet, a solution? thanks.
I am still trying to figure out how to post a signature.
2000 XK8
Old Jul 6, 2014 | 12:45 AM
enderle's Avatar
Default switch
Is the switch working properly otherwise? Locks down (typically off) then pops up (typically on)? Likely it is a switch failure because a transmission fault either keeps it from going on or causes it to flash.
Old Jul 6, 2014 | 01:45 AM
Nateward's Avatar
Why would you want to turn sport mode off?
Old Jul 6, 2014 | 04:52 AM
jamdmyers's Avatar
Mine did the same, replaced switch. Not much to them and the latching part is very small plastic I couldn't fix it.
Old Jul 7, 2014 | 08:47 AM
rednax's Avatar
Thanks Rob. The switch will not stay latched in the down (off) position. I will try to replace it.
Old Jul 7, 2014 | 10:56 AM
p-Rock's Avatar
I had the same issue...ended up going to Portside and found an old sport switch but didnt have the same female end and wouldnt light up or respond...swapped my good "board" from my sport switch and moved it to the good used "shell" sport button. works fine now but the bulb burnt out for the button itself (not the red light but the overlay).
Forcedair1
Sep 8, 2025 01:57 PM
34by151
Sep 6, 2015 05:14 PM
Mosers63
Sep 6, 2015 02:53 PM
02jagstype
Sep 4, 2015 08:20 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
