Spring Swap
Old Jan 19, 2012 | 04:50 PM
Skid Mark's Avatar
Originally Posted by Alag
Looking very snug and well poised.Will be interesting to hear how you find the ride and handling after you have put it through its paces for a few weeks,
Al
Originally Posted by The Coupe
Ah yes...much better, Skid. Looks great. Well done.
Thanks Al, plan to do some of that over the weekend! Will report back
Coupe, I put those thumbnails there just for you! Glad you saw them!
Old Jan 19, 2012 | 04:54 PM
Skid Mark's Avatar
Originally Posted by f-xo
Hi Skid Mark,
Nice job... When your car will be parked outside (unless you have a really big garage !), could you please make a picture of it showing it in profile, really square ? I'm very much interested by doing the same mod on my car and btw I have the same wheels. Question though : do you have CATS suspensions ? I'm wondering if there's not a difference in spring and body height depending between CATS and non-CATS...
Thanks !
Sure, I can get a profile shot. Soon as the sun comes back around!
I think CATS is an XKR feature, so no, I don't have it. Perhaps that's why XKR's always seem to be sitting level.
Old Jan 19, 2012 | 05:30 PM
Paul Pavlik's Avatar
Hi Skid Mark,
Thanks !
This is my XKR (with CATS of course) Lowering Experience.
https://www.jaguarforums.com/forum/x...omplete-54377/
Old Jan 19, 2012 | 05:50 PM
Skid Mark's Avatar
Guess that blows my theory about XKR's always sitting level. Does CATS just stabilize roll?
Old Jan 20, 2012 | 12:13 AM
avos's Avatar
Originally Posted by Skid Mark
-2 degrees wow! Jag shows -1.25 as the rear camber limit. How much did the camber change from where it was before? Did it go from -0.8 to -2.0 just because you lowered it?
Before it was about -1 degree. So on my car it has offset the rear about 1 degree with the 1" lowering Eibachs.
Old Jan 20, 2012 | 02:36 AM
f-xo's Avatar
Hello Paul,
Is the rear quarter view in your profile before or after the rear lowering ?
I love it anyway ('cause it's BRG !)
Old Jan 20, 2012 | 06:33 AM
Skid Mark's Avatar
That's a lot, better get mine checked as well. Thanks.
Old Jan 20, 2012 | 09:09 AM
  #28
Hello Paul,
My profile pic is Before the Lowering.
You mean that they actually offer other colors than British Racing Green?
Old Jan 20, 2012 | 10:53 AM
f-xo's Avatar
Dunno. But mine too is BRG
Thanks for your answer !
Old Jan 20, 2012 | 10:59 AM
  #30
mjlaris's Avatar
Hey Skid, I really like this look but do I understand you correctly that you only lowered the rear? I think I'll add this to my next list of mods for next year; haven't got this year's mods done yet.
Mark
Old Jan 20, 2012 | 11:30 AM
  #31
Skid Mark's Avatar
Mark
That's correct, the front was low enough, and just wanted to have equal space between the tire and fender opening on the front and back. Worked great!
Old Jan 22, 2012 | 12:34 PM
  #32
Skid Mark's Avatar
Hi Skid Mark,
Thanks !
Here you go XO. Would have been sooner but the weather has not been cooperative:
Old Jan 23, 2012 | 01:12 PM
  #33
f-xo's Avatar
Thanks a lot ! Makes quite a difference... Since installed, have you noticed any behavior or balance change with only the rear spring rates being modified ?
Old Jan 23, 2012 | 01:24 PM
  #34
The Coupe's Avatar
f-xo;
I can't speak for Skid, but if anything the handling of my car is a bit more crisp since I lowered the rear by 1.25". It was good before the change, and a bit better after. Certainly no deterioration in handling or unpredictability.
Old Feb 4, 2012 | 09:21 AM
  #35
avos's Avatar
Used this formula to determine the right shim thickness:
0.5 mm divided by 150mm (aprox distance axle to the hub bolt (centers)), then tan-1 and you get 0,19 degrees.
Have just fitted a 3mm thicker shim (so 6*0.19) to get aprox 1.14 degrees off, now I only need to have it measured professionally, roughly it ssems to be slighly less then -1 degrees. It looks already much better again.
Old Apr 11, 2012 | 03:14 AM
  #36
avos's Avatar
Finally got around to do the new alignment, and the calculation is about right, I went to about -0.85 degrees. However as also the toe needed adjustment, the camber got further to -0.66 as you just have 1 bolt to adjust the 2, but am happy with it.
Old Aug 12, 2013 | 02:21 AM
  #37
User 070620's Avatar
Have changed my springs to Eibachs now a couple of weeks ago, although the front was perfect (contrary to the back) as after almost 200Kmiles the original springs where already a bit lowered by themselves, and the upper shock bushing was also 5mm more compressed (bought new ones though).
Have also done it myself on the garage floor with spring compressors, it’s doable. It was certainly worth it and the car is now level again ;-).
I know in the past Eibach provided shims also, and although maybe not necessary, I will check the camber this week and may adjust it pending on the values. I certainly don’t want to wear out the inside of the tires only, not so good for traction either.
Hi Avos,
can'i know where you had buy your Eibach sport springs?
SD96XJ6L
Dec 27, 2025 09:58 PM
Dave1109971
Dec 15, 2015 06:16 PM
multistrada74
Oct 8, 2015 08:58 AM
Bcrary3
Sep 27, 2015 12:21 PM
