squeak!!!!!!!
Old Jun 13, 2011 | 02:11 PM
Tageitelman's Avatar
Default squeak!!!!!!!
I have developed a very loud speak that sounds like it is under my dash. Every bump in the road and it squeals. So loud and constant that you cannot hear radio. Help!!!!
Old Jun 13, 2011 | 03:10 PM
DarrenT's Avatar
Hey Tag,
I had a similar problem w/ my 2000 XK8 driving it home from purchasing it in Florida (about a 600 drive one way and this started about half way...); drove me crazy the whole way. The sound was like a metallic squeak every time we would drive over a bump in the road, didn't matter how slow or fast we were going. It turned out for me to be the front, upper shock isolators. They had detriotated...another material problem. A couple hundred bucks if you do it yourself then an alignment would be a good idea. Good luck!
DT
Old Jun 13, 2011 | 03:59 PM
Smixon's Avatar
Just started digging into my annoying "squeak" this morning and, like DarrenT, it appears to be the upper shock mount bushing. If you pull the black caps off of your shock towers you'll be able to get a decent view of the condition of those bushings. My driver's side is completely gone and the top of the shock is clearly scraping against the side of the tower opening. Strangely, the right side looks fine (I hear the right side is normally the first to go out).
Scott
Old Jun 21, 2011 | 08:15 AM
lorwood's Avatar
Just developed the same problem on my 03. Any tips/hints or even better step by step on how to replace? Also whats the best source for parts? Thanks!
Old Jun 21, 2011 | 09:25 AM
motorcarman's Avatar
Here is some additional info.
bob gauff
XFactoR
Oct 26, 2017 08:10 PM
JimC64
31
May 30, 2016 03:04 PM
Bcrary3
Sep 27, 2015 12:21 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
McJaguar
Jan 28, 2009 11:08 AM
