Squeaks in front end suspension
Old Sep 7, 2011 | 02:04 PM
cornhusker66's Avatar
Default Squeaks in front end suspension
This is my first Jaguar and so far it has been a very nice cruiser. Decent power, nice ride and cornering. Heck even good mpg's provided I keep out of the accelerator.
However, with all that being said, I hear some creaks in the front end. They are especially noticeable as I back out of the garage in the morning. I just looked under the car and bushings look good. Well at least what I can see without getting the car raised off the ground.
I bought the car from the Jaguar dealership in Omaha. They gave the car a clean bill of health.
These squeaks, or groans remind of poly bushings after being installed. Is there a common problem that causes this?
Thanks.
Old Sep 7, 2011 | 07:56 PM
Danster's Avatar
Check the sway bar bushings. I had the same symptom, changed mine, and no more noise. Not expensive or complicated to change. Hope This Helps.
Danny
Old Sep 7, 2011 | 09:10 PM
Reverend Sam's Avatar
My squeaking cleared up after I replaced the upper front suspension bushings. For instructions on how to replace those, and on how to replace the sway bar bushings as Danster suggested, click on the link down below in my signature line. That will take you to my youtube channel where I have videos on how to do both jobs.
Old Sep 9, 2011 | 11:03 AM
XKR Brian's Avatar
check the torque on the "x" bar that is bolted on under the engine. I had one driving me crazy only over uneven roads and when backing out of driveway and those bolts were the culprit. You can check bt pulling down on the x brace, and it will make the noise if its it.
Old Sep 9, 2011 | 08:23 PM
mike66's Avatar
Cornhusker, what year and type of XK do you have? Should put it in your signature somewhere so we can make a reasonable half-assed guess.
Can you systematically apply some lithium grease to different suspension areas until you find the culprit? If you have a pre-2000 car, probably time for the old front end rebuild.
Old Sep 9, 2011 | 09:20 PM
2002XK8Orlando's Avatar
Front struts start squeaking when they are going bad..and get damn loud eventually to where the radio won't even drown out the squeak
bamforp
Aug 14, 2024 05:36 PM
trosty
26
Dec 18, 2022 06:40 PM
GordoCatCar
Jan 2, 2017 01:10 PM
obwoodie
Sep 3, 2015 07:45 PM
arnoldmilk
Sep 3, 2015 07:42 PM
