Starting issue.
,I've owned my 2000 XK8 for a few months, but just registered it today. Here's what's happening;Drove it 30 miles today, and started it several times throughout the day. Got it home, and parked it for a few minutes then tried to start it again. All lights come on, but the starter wont engage, Not even a click. Put a voltmeter on the battery, shows about 12.8v. tried everything I could think of; seat belt on, foot on brake,...nuttin'. I'm pissed off so I'll get back on it tomorrow. Where do I start? Thanks guys...
During the previous start attempts, I had tried neutral for a start, no joy. After two beers and some chow, I was compeled to head back to the garage. Inserted key, rotate, started instantly. I'm also wondering about a possible dirty ground at the starter? I appreciate your input...
Fuse and Relay information is in the Vehicle Care Handbook. If you haven't got this or any of the other Handbooks for your vehicle, they can be downloaded in PDF format by following this link:
https://www.jaguarforums.com/forum/x...-2003-a-67827/
https://www.jaguarforums.com/forum/x...k8-help-41309/
Maybe the same problem? I had similar problem except nothing would light up........a couple of hard resets through the past year have handled the problem. Always carry that spare wrench for the - terminal on the battery, it can be your best friend when your wife gives you THE LOOK.
Pulled the starter relay and replaced with new. I've probably done 25 starts in two days. So far, I have not been able to duplicate the problem. Gremlins...? If it happens again, I'll replace the starter/solenoid. Thanks to you guys for the input. Bob
No start, more often. Tried everything, including a reset. Turn the key on ,get the fast clicks from the relay, but no turns on the starter. On one of the first attempts ,the starter did begin to turn a few teeth, then quit. Nothing on the last 20 start attempts. Battery fully charged, cleaned the grounds, tightened everything. Ideas? thanks, Bob
Use this link to my no start and go down to the Power distribution and Starter and see if it provides a little help.
And maybe attached diagram will help you find it
Jacked the Jag, and slid underneath. We had removed the starter back in May, cleaned the solenoid and put it back in. This time, I went under and loosened and cleaned the ground strap. I then took a drift with a small hammer and gave the starter motor a good spanking. Seems to be working good now... bought a reconditioned starter from Pep Boys ($148.) + $55 core, will put it in tomorrow. Suggestion to my Jag colleagues , keep the hammer at the ready... Thanks all, Bob
