Steering wheel wiring loom connector advice.
Old Jan 19, 2025 | 08:38 AM
Phil m's Avatar
Default Steering wheel wiring loom connector advice.
I've recently replaced the cassette under the steering wheel on my 1999 XKR convertible but when I removed the upper and lower cowls trim which a previous owner had clearly removed before I found an electrical connector not connected to anything, see the pictures below.
the connector on the right is the one in question, the other is for the dashboard illumination dimmer.
the above picture shows the black cable (southeast corner) running from the connector in question and joining a larger wiring loom.
I don't want to put everything back together until I know what this connector is for so I would really appreciate some advice?
thanks in advance.
Old Jan 20, 2025 | 10:55 AM
Brian G's Avatar
It appears that you do not have power steering column positioning on your car? The control switch for that function is located adjacent to that dimmer switch.
Old Jan 24, 2025 | 08:17 AM
Phil m's Avatar
Apologies for the delay in replying Ive been away, your probably correct Brian I expect it s for the power steering column adjuster that my car does not have.
Thanks for your adive.
Mozambique
Jan 12, 2024 04:05 PM
vrajes
Feb 23, 2023 08:36 PM
4zfed
Dec 9, 2021 02:56 PM
ckmot
Nov 3, 2020 08:54 PM
adriaxj8
Dec 13, 2012 05:20 PM
