strange AC
Old Sep 7, 2018 | 09:34 AM
larueb's Avatar
Default strange AC
Gus,
It is still hot in Florida and yesterday had a strange AC experience with my '99. The AC was blowing cold on the drivers side and hot on the passenger side regardless of the settings. I had
the outside air mix turned off. I waited for it to all blow cold but passenger side stayed warm to hot. Any clues?
Thanks!
LaRue
Old Sep 7, 2018 | 01:08 PM
oldmots's Avatar
You may have a stuck blend door, each one has a motor, it may need to be looked at.
Old Sep 7, 2018 | 01:27 PM
Jon89's Avatar
^^ Agreed. The blend doors and their servo motors should be the initial suspect....
Old Sep 7, 2018 | 01:55 PM
rothwell's Avatar
Since you are in Florida you might have issues like I had where the foam bits in the dash are decaying into goo. It is worth pulling out all the vents to check and clean. Gets rid of that musty smell too.
Old Sep 7, 2018 | 02:32 PM
avern1's Avatar
Blend door may be the problem but if you have air out of the vent then it is most likely the system is low on refrigerant. The normal is for the driver side to get hot air and the passenger cold but that is not always the case. I would get the systems pressures checked especially if it has not been serviced in awhile.
summerwind
Oct 9, 2009 07:31 AM
seeyouincourt28
Aug 11, 2007 07:05 PM
Smidgy
Mar 16, 2007 05:34 PM
Mar 2, 2007 04:08 PM
