Stuck ABS wheel sensor
Old Jan 14, 2018 | 06:24 AM
renaultvation's Avatar
Default Stuck ABS wheel sensor
I need to replace one of my front wheel sensors, but the existing sensor is stuck fast and does not wish to budge. I have removed the bolt and soaked the sensor in penetrating fluid. I have tried levering and twisting, but with no luck. I have not used too much force as I don't wish break it. Has anyone else had the same experience and found a simple solution?
Old Jan 14, 2018 | 07:29 AM
Jon89's Avatar
Try heating it up with a hair dryer. Five minutes or so of a hair dryer set to "high" may be enough to break it free with light taps from a rubber mallet after the sensor casing gets hot enough....
Old Jan 14, 2018 | 09:07 AM
Success: Lots of gentle persuasion and leverage and a little heat as suggested and it started to move a little. Much more of the same together with penetrating fluid and out it came. Now to order the replacement and hope it goes in a little easier.
Old Jan 20, 2018 | 12:15 PM
New sensor arrived today (cost me £11 on Ebay). Couldn't wait, so fitted it in the rain. I am pleased to report that all warning lights have now disappeared and the ABS and traction control are working.
rp2427
Sep 12, 2014 06:55 AM
dijmand
28
May 19, 2014 12:44 PM
Noxparadise
Apr 29, 2012 06:23 AM
babbah
XJ40 ( XJ81 )
Sep 14, 2010 04:58 PM
