Subwoofer Solution, v4 (and hopefully the last!!)
Old Jun 8, 2011 | 01:55 PM
H20boy's Avatar
Default Subwoofer Solution, v4 (and hopefully the last!!)
A couple of you knew I was working on another subwoofer enclosure option for the backseat of my xk8. Allow me to give you a timeline before I detail the project for what I hope will be my final solution to get decent bass in this car. Note in all scenarios, I had an aftermarket amplifier installed to provide all required power.
Version 1: I replaced the 6-inch OEM woofers with JL Audio 6w0 and then JL Audio's 6w3 units, which were a step up from the original alpines, but not what I was accustomed to having, and needed more of the punch.
Version 2:
I had a guy carve the rear seatback cushion's foam and he built a box that fit into it (facing the trunk) and it held two (8") JL Audio 6w3s. Again, it was better, had lots of that tighter bass capability, but not the lower frequencies, and the box sorta bumped out of the seat cushion's leather, yah...you could see it was there. Not happy in aesthetics nor performance. (No pics, sorry...lasted only about 3 weeks)
Version 3: I needed a bigger subwoofer, at least a 10-inch, so I bought a JL Audio 10w6, it was one of their top units at the time, and needed the least amount of space for a sealed box (0.625 ft^3) without going to the 10w7, which is their prized sub, and takes a whopping 1.25 ft^3. With the size of the xk8's cabin, I figured a 10-inch would be more than enough, if it was enclosed properly.
Only problem was I had no room for this, so I thought maybe a fiberglass enclosure, secured to the back seat (via a hidden bracket) would be enough to satisfy me. This was a good solution, and lasted about 1.5 years before I changed it. I could not move/recline my seat back the entire way, and I was annoyed about that. Also, the color of the vinyl they wrapped it in did not match, that bugged me. And finally, the passenger could never feel the same bass as the driver, due to the nature of the installation, and the cushion dampened any 'bass' vibration that could be transferred to the passenger through the car's frame/body.
Version 4: I went to my audio shop in Ft Worth (Woody's Car Audio) and their new enclosure guy, James, was touted as an expert in his field. I explained what I wanted -
1. pull out the rear bottom seat cushion for easy re-installation in the future if I want
2. fabricate a subwoofer enclosure behind the driver, that allows me to move my seat and recline fully, use the JL Audio 10w6 in the car
3. keep the passenger side available for children and my dog to use, 150 lbs max weight, seatbelts must still be operational
4. wrap the new 'seat' and enclosure to closely match the original style, and use genuine Connolly leather perfectly matched to the OEM color
Here is what it looked like, original seat -
Here is what I received, after 1.5 months of their work, in and out for 'test measurements' and final upholstery work. It actually is TWO separate pieces, one is the sub enclosure, the second is the remaining seat. The seat uses the same two (2) fastening points as the original did, he did a great job.
Some 'construction' pics, courtesy of James showing a few stages of the fiberglass work.
The body and wiring, under the rear seat (driver side)
I spent alot to get this final product in case you're interested (most are) - over $800 in labor for the audio shop to build/install the enclosure, $50 in shop supplies, $475 for 3 yards of dove grey leather (I have alot left over BTW, PM me for pieces if you want to buy some material) and another $500 labor for the custom upholstery work.
Result - sounds GREAT, lots of bass, and I have soo much more room for my driver's seat now!!! James informed me that my previous box was WAY too large, I measured the internal volume and found 1.3 ft ^3 available...that last guy didn't know what the heck was going on, apparently. Attic paperweight it now becomes.
James is open to do this again, and it should be considerably less to do a second time, if you so desire.
Hindsight thoughts
  • I should have cut my original rear seat cushion up, and saved about 1/2 of the construction & upholstery costs. Like I'll ever need to put it back in to sell...not when it looks that good. Oh well, live and learn.
  • Black interior color also would be much easier, and cheaper to upholster, good gracious this dove is pricey to match
Its been done for a couple weeks, and after tweaking the 3sixty.2 for this new setup, I am absolutely thrilled with the overall system. The 10-band EQ for the subwoofer channel really helped tune that frequency range.
Yay! I'm off to listen to it again over lunch!! For those of you who don't know about the rest of the gear in the car, take a look here for more info.
Old Jun 8, 2011 | 03:08 PM
XKRacer's Avatar
Love it when someone does something from the norm...... good job
Old Jun 8, 2011 | 09:57 PM
K.Westra's Avatar
Much more extreme than what I will ever go, but very cool! One of these days (or months) I will replace the rear subs, but for now, I'm rolling stock Alpine.
Old Jun 9, 2011 | 01:39 AM
Frog's Avatar
Wow, that is indeed a lot of time and money spent. You must really like your bass. It's a neat install, but as K. Westra says, a bit extreme for me. Enjoy
Old Jun 9, 2011 | 03:19 AM
Cadillac's Avatar
Extremely fantastic job
Old Jun 9, 2011 | 10:50 AM
Gameblaster1's Avatar
Thumbs up
Oh man! That looks so CHOICE! Outstanding job!
Old Jun 10, 2011 | 05:05 PM
turbo68's Avatar
Now that makes me look bad that I have been procrastinating about getting installed my KICKER CVT654 Sub Woofers that I had purchased a long time ago but just cant seem to find the time to install. Now it is time!!
Nice Work!!!
Old Jun 10, 2011 | 11:20 PM
EZDriver's Avatar
You're just having too much fun with that car!!!!! Looks really great. Good job.
EZDriver
Old Oct 24, 2014 | 08:34 AM
aode06's Avatar
interesting you did all that for the subs.
I just dyno matted the trunk, installed 2 12's in a sealed box, put the convertible top up, opened up the vents from the interior to the inside.
The two rears were replaced with 3 ways.
System slams
Old May 7, 2015 | 12:03 PM
Majik Lasers's Avatar
No problems with the bass penetrating the fuel tank into the cabin? Any sound difference when the tank is full vs nearly empty? (I assume the convertible's fuel tank is located in the trunk just as the coupe...)
Old May 7, 2015 | 01:29 PM
marvin.d.miller's Avatar
Talking Looks great, but I'm a little confused.
In iteration #2 you said you weren't happy with the esthetics. So, you took out the setup, and in iteration #3, you installed what appears to be the sonic equivalent of a Minion from the movie "Despicable Me". I can't blame you for removing that one.
But then in iteration #4, although it looks awesome and I bet it sounds incredible, you installed what looks like, for lack of a better term, a porta-potty disguised as a speaker.
Don't get me wrong, I'm very impressed with the installation and give you kudos, but....
Old May 11, 2015 | 10:54 AM
H20boy's Avatar
LoL, Marvin...I suppose it does look a bit odd, but with the driver seat back, the sub box doesn't look like a porta-potty. I just told the fabricator to use that area for the sub, and since there wasn't enough volume below the original seat, he chose to make it protrude vertically.
Old Jan 29, 2017 | 02:16 PM
2e0wdj's Avatar
Hi Mat
I wanted a bit more low end as well but yours certainly puts my budget job to shame.
A few images of my install if you are interested.
It just gives me that little bit lower end than the cabin speakers.
Attached Thumbnails Subwoofer Solution, v4 (and hopefully the last!!)-dsc_0378.jpg   Subwoofer Solution, v4 (and hopefully the last!!)-dsc_0384.jpg
Old Jan 29, 2017 | 03:44 PM
hm1's Avatar
hm1
Originally Posted by 2e0wdj
Hi Mat
Clean! This is how I would do it. Looks almost factory
Old Jan 29, 2017 | 04:30 PM
2e0wdj's Avatar
Hi
Thanks, the IB sub sits just about one inch above the space saver spare wheel and the little compartment allows me to have a cubby hole to put the spares etc in without lifting the floor every time.
Old Jan 29, 2017 | 08:56 PM
hm1's Avatar
hm1
Hi
Do you have more pics, like of the little compartment? I really like this
Old Jan 30, 2017 | 02:21 AM
2e0wdj's Avatar
Hi hm1,
Yes these are what I took while assembling it.
Attached Thumbnails Subwoofer Solution, v4 (and hopefully the last!!)-dsc_0379.jpg   Subwoofer Solution, v4 (and hopefully the last!!)-dsc_0380.jpg   Subwoofer Solution, v4 (and hopefully the last!!)-dsc_0381.jpg   Subwoofer Solution, v4 (and hopefully the last!!)-dsc_0382.jpg   Subwoofer Solution, v4 (and hopefully the last!!)-dsc_0383.jpg
Old Feb 4, 2017 | 03:06 AM
H20boy's Avatar
Wow, thats amazing that you had enough room to keep the spare also. Very nicely done!
Old Feb 4, 2017 | 09:24 AM
2e0wdj's Avatar
Thanks H2O, just tinkering at the moment. I've put a set of Focal 2 ways in the front now and putting the Polk 2 ways in the pods at the back.
The Thin IB sub lets me get away with keeping the spare wheel as well.
Regards
Wayne
oldjaglover
Dec 25, 2024 04:33 PM
mikiep
Dec 20, 2019 07:37 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Presence
Mar 13, 2016 02:21 PM
Rocky15
Sep 28, 2015 04:59 PM
