Subwoofers in Coupe Trunk & Fuel Tank
Old May 7, 2015 | 04:52 PM
Majik Lasers's Avatar
Default Subwoofers in Coupe Trunk & Fuel Tank
I’m very in to car audio. When purchasing my 04 XKR coupe, I had no idea the fuel tank was in the TRUNK! I’ve never seen that before…and I was a mobile installer for a few years back in 99-01, wiring hundreds of vehicles…actually seems like a safety hazard in the event of a collision.
Anyway, has anyone installed aftermarket subs in the trunk? If so, how does well does the bass transfer in to the vehicle’s cabin after passing through (and around) the fuel tank and factory sound deadener?
Old May 8, 2015 | 05:12 AM
It's safer than having an under slung fuel tank rupture in a collision and deposit the contents onto the hot exhaust pipes!
I'm not into audio installation so don't bite my head off for this suggestion but comparing the premium audio setup and the convertible rear speaker locations could give you some ideas on speaker positioning.
Old May 8, 2015 | 11:02 AM
x-biker's Avatar
I had a 10" sub enclosure built into the left hand side of the boot/trunk - thank god I agreed to also have the sub-volume adjuster fitted as even with it behind a full tank of fuel it still kicks you in the back, re-arranges your internal organs and makes your hair stand on end. If you go that route I would recommend installing sound deadening material as well to stop all the bodywork buzzing. I had the boot lid, floor and inside of the rear quarters done, as well as the doors.
Enjoy!
dsnyder586
Dec 29, 2024 07:39 PM
Razor
Aug 28, 2019 08:34 PM
XJsc-guy
Nov 23, 2015 01:56 PM
hen555
Sep 7, 2015 11:13 PM
deanh
Sep 6, 2015 08:20 PM
