Temp gauge
Old Jul 4, 2015 | 07:59 AM
reb1999's Avatar
Default Temp gauge
Hi all, To all yanks, Happy Birthday...
Just wondering if anyone knows the location of the sensor, or sensors which feed the on board computer temperature its temp readings.
In fear of an overheat, and knowing the dash gauge ( light) is not accurate, I installed an OBD Scan Gauge.
Seems to work well. Very sensitive. Varies up and down a degree or two often.
Two observations. Just changed oil with a thicker 15w 40 Mobil one as ok'd range in my owners manual. Temp on highway seems a little higher than with the thinner oil.
2nd, cools down 4 to 5 degrees speeds in excess of 80mph.
Thank you all. Rich
Old Jul 4, 2015 | 10:49 AM
WhiteXKR's Avatar
Everything you posted sounds reasonable.
The location of the sensor is front and center at the top of the engine. This same sensor also informs the ECU.
workworkwork
Oct 23, 2015 10:26 AM
vwbusbits
Oct 13, 2015 03:43 AM
3lvis
Oct 1, 2015 01:56 PM
reb1999
Sep 26, 2015 08:41 AM
