TerraClean in the U.S?
Hi guys,
I hate bringing TerraClean up again as a subject, but I swear I've gone through just about every thread on the subject. I've been all over the net as well and I can't find out if the service is available in the U.S., and even more importantly, WHERE in the U.S.
Let's not debate whether the treatment works or not. I just need help finding the service, ... "or" if some U.S. competitor has come up with a truly equivalent treatment (i.e., not just a fuel additive).
As always: THANKS!
As always: THANKS!
Received 9,005 Likes
Why not shoot them a mail, or call them to see where if / any dealerships are located in the US?
http://www.google.co.uk/url?sa=t&rct...62286460,d.ZG4
Good luck
Good luck
Had mine done just a week or so ago, previously had it done on my A6.
I have to say I reckon I have about 3-5 mpg better average over the last 150 miles or so as far as I can tell to date.
Unsure on the emmissions but it certaianly hasn't made it worse!
I hope to be able to build a better picture in the coming weeks & months, but happy to date.
I have a flexi pipe cracked thats causing an exhaust leak near the manifold, hope to have it fixed soon and I reckon that may improve it further still
Let us know how you get on Scardini......what they say, how much and if you go for it or not and of course the results if you do?
Thanks guys. All good.
Woo-hoo! A dealer in Maryland. Unbelievable - it's as far from me in the State as is just about physically possible - over 3.5 hours. (lol).
If nothing else, I can contact them or TerraClean home plate to see if there's a location nearer to me. At least I know it exists here. Cool.
For those who might be wondering why: My previous engine (which is no more - whimper) had been burning quite a bit of oil. My 50K mile replacement engine runs just great, but even after replacing both lower O2 sensors and a few gas treatments, I'm still getting P0420/P0430 codes (catalytic converter efficiency). So I'd like to blast the cats with a TerraClean wash and see if that finally clears the problem.
JimC64 (03-04-2014)
Received 2,255 Likes
I have heard that around here (Pacific Northwest U.S.A.) the catalytic converters get fouled by sulphur from Alaskan crude. No amount of heat fixes that.
If they are fouled by oil then getting them hotter than normal might help. I try to get mine as hot as possible as preventative maintenance just in case.
When I had the exhaust off a few weeks ago I had peek at the cats; sparkling clean inside and the ceramic was bright white. Not bad for 85k miles, and have had the water meth kit installed for the last 15k or so.
*disclaimer: circumstantial evidence, I don't know what they looked like before the water/meth.
SCardini1, I contacted the parent company of Terraclean and one of their reps contacted me. There are several places in Los Angeles that use the system but most are in dealerships. So, Mercedes dealers and BMW dealers were not to be found for the Jaguar. But, there was one independant shop in my area that had the system. I don't think he had many customers use it. But, he did use it on his own cars. So, that's how I found Santa Monica Auto Center. Eduardo is a funny guy. In a good way.
Mikey, the car is running good. But, as you may know carbon deposits are going to be present in a car with close to 90K miles. And a new engine is the optimum engine, So, if I can clean it out from injector rail to tail pipe and eliminate most all of the carbon deposits, I try it.
The first thing I noticed is more grunt down low. And it sounds smoother. That could be my imagination. But, it does feel smoother and that is not my imagination.
We'll see how long it lasts. Some have reported it get incrementally better as you build the miles. Some say the improvements level off but that it is better than before. We'll see.
One thing that was pretty cool is that the rep came to the shop and ran the process for the shop owner. He walked me through the technology and the process as the car was being done. There is not much to do but connect it and turn it on. But, it did give me confidence that it was being done correctly.
If a significant difference is noted before/after, there is an underlying problem that should be addressed.
