Things not connected??
Old Apr 15, 2025 | 04:23 PM
JetCity's Avatar
Default Things not connected??
I looked through the posts and see question about things in the trunk that we find not connected. I’m glad to be getting a new battery and found these two cable/hose loose when I (well the strong kid next door) pulled the battery. I’m sure we did not bump anything.
Old Apr 15, 2025 | 11:40 PM
giandanielxk8's Avatar
Ahh yes, they all have that. It's the harness for the wine and champagne cooler they were planning to offer as an option but the Ford bean counters shot it down.
Old Apr 16, 2025 | 04:18 AM
jimbo110's Avatar
The first picture is the battery vent hose and will need to plug into your new battery on the end of the battery.
Old Apr 17, 2025 | 01:47 AM
JagV8's Avatar
For transit relay?
Old Apr 17, 2025 | 03:09 AM
dibbit's Avatar
It looks like it's the wrong shape connector for the transit isolation relay, unless later cars had a different design. There is also a connector for the boot accessory socket around there somewhere - the only way to be certain is to check the wire colours against the electrical guide for that year car and test the connector with a multimeter. Or alternatively, ignore it.
Old Apr 17, 2025 | 08:05 AM
motorcarman's Avatar
The X100 has that transit relay. The unit has three connections. (five if you include the negative post in/out connection)
One is the relay trigger and the double male is for the two door modules for the window drop/rise upon opening/closing.
Old Apr 17, 2025 | 09:29 AM
dibbit's Avatar
The related thread feature has finally produced a useful result - these are the connectors for the transit relay:-
https://www.jaguarforums.com/forum/x...1/#post2711942
Nice clear photos in that thread.
Old Apr 17, 2025 | 11:47 AM
The Lucar connector referred to in the post is the transit relay actuator wire.
That is what the ignition key activates to turn the relay on to energize the car. The windows (door modules) are powered ON at all time so the window glass is not damaged when the doors are opened with the power disconnected by the transit relay.
Old Apr 18, 2025 | 03:20 AM
dibbit's Avatar
I think you might be the only person on this forum who has actually physically seen one of these transit relays, whereas everyone else has seen the connectors and thought "what are these for?". I wonder if that loose Lucar spade connector has ever accidentally made contact with the battery positive terminal for exciting results.
thegreatgarbanzo
Jan 13, 2024 01:05 PM
Reaxions
Apr 20, 2022 04:02 PM
okmores
Jan 30, 2022 05:37 PM
MarioBrragan
Apr 11, 2020 08:11 PM
mcamp
Nov 25, 2018 10:53 AM
