Third XKR boot mounted brake light
Old Oct 29, 2012 | 12:00 PM
Minnievirginny's Avatar
Default Third XKR boot mounted brake light
Hello Folks,
Well, I saw one of the leds looking a bit dimmer than the rest and fondly imagined I would be able to visit the jag dealer, get ripped off for a single led (or perhaps an entire array - worst case scenario) but no........
I need to buy the entire incredibly expensive unit.
Got home, removed it and sure enough its glue/plastic welded closed.
Anybody experienced this? I am determined to take it apart and fix it. After all its only a single led failure.
Sorry if this subject has been covered already - couldn't find a link
Cheers all,
Laz
Old Oct 29, 2012 | 01:53 PM
WhiteXKR's Avatar
See https://www.jaguarforums.com/forum/x...-repair-27177/
Old Oct 30, 2012 | 08:02 AM
Thanks for the link.
I should have mentioned the array is for an XK convertable. It sits on the boot lid and is seriously glued together.
Old Oct 30, 2012 | 08:36 AM
Laz,
When I read your original post yesterday, I had a look at the convertible third brake light. Sure enough no individual parts listed and they appear very hard to source other than at the dealer.
They've certainly been determined to make it waterproof.
I've checked the UK specialist Jaguar breakers but none are showing a used item as available in stock.
There is one listed on eBay UK:
Jaguar XK8 XKR Convertible Rear Brake Light | eBay
If you can't source one in the US at a reasonable cost, this may be worth taking the hit on the international shipping charge.
Old Oct 31, 2012 | 11:55 AM
britannia's Avatar
Laz,
I got a replacement from Hawaii ! spoilerlights.com $54 w/shp.for my wifes 2000 XK8 conv. 15.5" long.
Hope this helps,
Adrian
Old Oct 31, 2012 | 04:12 PM
Thanks for the heads-up folks. As if by magic I found one about 25 miles away on ebay - £40. Should arrive in the next few days. This means I have a whole heap of replacement leds if I need to perform surgery in the future
By the way Graham, I am in the UK
Regards to all,
Laz
toronadomike
Jan 22, 2026 10:13 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
obwoodie
Sep 3, 2015 07:45 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
