timing chain tensioner bad ?
Old Aug 29, 2007 | 10:21 PM
2000blackxkr's Avatar
Default timing chain tensioner bad ?
Ok, how do i know if the tensioner need to be replaced? I have noticed that there is a little bit of a rattle right on start up and it goes away almost instantly. is that the issue?
Old Aug 30, 2007 | 09:11 AM
ken@britishparts.com's Avatar
Default RE: timing chain tensioner bad ?
Yes, that's the issue. Do the timing components know and save yourself the expense of an engine. Once you do the timing stuff with the latest, greatest upgrades, these cars are a dream.
Old Aug 30, 2007 | 12:00 PM
Ken, I noticed that according to Alldata, there is some special tools needed to complete the replacement. Do you know ware i can get these?[&:]
Old Aug 30, 2007 | 02:56 PM
We sell the set of 4 for $285. I would recommend getting a second cam tool so you can do both sides at the same time and not switch the tool back and forth, but that will cost you another $95.
Old Aug 30, 2007 | 04:03 PM
Ken, What is included in that kit?
does it include the parts or just the tools?
also does it give you new valve gaskets?
Old Aug 30, 2007 | 04:16 PM
That kit is the four tools. The timing chain kit I can take $100 off and make it $650 and the valve cover gasket kit I can move to $60. You are looking at $995 for the parts and tools. I have it all in stock.
Old Aug 31, 2007 | 05:59 PM
Ken,
My car runs absolutley flawless except for the slight rattle at start up. Do you think i shold replace just the #2 tensioner or should i replace all of them?
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
user 652867429824
Sep 5, 2015 12:53 PM
Sprayall
Sep 3, 2015 07:49 PM
