Timing chain tensioners
Old Apr 15, 2019 | 03:49 PM
murphy007's Avatar
Default Timing chain tensioners
I own a 2002 xk8. Is there any way of verifying wether the tensioners for the drive chain are the plastic or metal ones without taking the engine apart? Manufacturing date was May 2002.
Old Apr 15, 2019 | 05:51 PM
Welcome to the forums murphy007,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Apr 15, 2019 | 06:51 PM
avern1's Avatar
There is only one sure fire way. Take off the passenger side cam cover (easiest) and look. If it isn't metal body pull the other cover and change them. Any other way is a crap shoot. Is my engine number high enough I don't have some left over in stock part installed?
Old Apr 15, 2019 | 08:41 PM
motorcarman's Avatar
Check the ENGINE NUMBER/DATE CODE (left side of block behind the engine mount)
bob
srpope80
May 17, 2019 09:13 AM
slanham
General Tech Help
Feb 1, 2014 06:34 PM
Apr 2, 2007 11:08 PM
